Code 17,How do i fix it?
Old Jun 7, 2003 | 08:37 PM
1EK1EG's Avatar
Default Code 17,How do i fix it?
ECU is flashing 17, which is vehicle speed sensor.Can anyone tell me how to fix it.TIA.
Old Jun 7, 2003 | 11:11 PM
b19coupe's Avatar
Default Re: Code 17,How do i fix it? (GreenCivicEg)
Does your speedo work? If it does, reset the ECU and see if the code comes back.
Old Jun 8, 2003 | 01:37 AM
1EK1EG's Avatar
Default Re: Code 17,How do i fix it? (b19coupe)
Yeah the speedo works fine.At one time i wasnt working right, then it started to work fine.I will try that and see what happens.Thanks.
Old Jun 8, 2003 | 07:12 AM
b19coupe's Avatar
Also, check the connector at the speed sensor, due to it's location it is subject to corrosion-look for a green residue on the metal part of the connector. If you have corrosion, you have to replace the connector.
Old Jun 8, 2003 | 11:19 PM
1EK1EG's Avatar
cool thanks,i tried resetting the ecu, but i didnt have any luck.Thanks again.
Old Jun 9, 2003 | 05:18 AM
3gdude's Avatar
Are you sure the code cleared?? That code should not set until you actually move or drive the car. That code may just be a memory code from when the speedo was not working correctly. Pulling the correct fuse to re-set the ECU doesn't always work if any accessories are powered up on that same circuit. Disconnect the battery or the ECU itself if the code wont clear.
Old Jun 10, 2003 | 01:09 AM
1EK1EG's Avatar
Default Re: Code 17,How do i fix it? (3gdude)
The code does not pop up when i drive, I had to rig it somehow to get the code.When the car comes on, the check engine light pops up and it stays on.
Old Jun 10, 2003 | 06:07 AM
b19coupe's Avatar
Code 17 should not pop up until the car is moving. Either it's not code 17, or your ECU is faulty. Make sure that you clear the code-disconnect the battery for at least 10 seconds. What does "rig" it mean?
Old Jun 10, 2003 | 10:20 AM
3gdude's Avatar
Lost me too.....Huh
Old Jun 12, 2003 | 07:14 PM
1EK1EG's Avatar
Ok, this is what happened.My check engine light came on.So I got a paper clip and connected it to some wires under my dash near my ecu.The check engine light then blicked 7 times followed by one long blink.So i called the shop and the man told me the long blink meant 10.10+7=17 which is vehicle speed sensor.The only other option is code 7 which is throttle angle.When i say i rigged it, i used a paper clip to get the code to pop up,but that doesnt matter.I just want to figure out how to get my check engine light off.
Old Jun 12, 2003 | 07:21 PM
b19coupe's Avatar
Clear the code-disconnect the battery.
Old Jun 13, 2003 | 06:18 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenCivicEg &raquo;</TD></TR><TR><TD CLASS="quote">...The check engine light then blicked 7 times followed by one long blink...</TD></TR></TABLE>
Code 17 would be one long & 7 short, in that order. Sounds like you have code 7 and code 10.
Code 7 = throttle position sensor
Code 10 = intake air temperature sensor
Clear it by disconnecting the battery cables like someone already said. Have your radio's anti-theft code 'cause you'll need it.
Old Jun 13, 2003 | 05:13 PM
untitled's Avatar
Default Re: Code 17,How do i fix it? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
this is correct.
LOC714
Dec 8, 2008 03:37 AM
ATS*Mark
Dec 8, 2004 06:13 PM
T--Rex
Jul 10, 2004 02:15 PM
IamVtec
12
Nov 2, 2002 04:50 AM
