Rev limit on a built motor ??
Old Jun 5, 2003 | 09:16 AM
boosted_zc's Avatar
Default Rev limit on a built motor ??
I'm just wondering if it's possible to rev my motor higher because it's fully built. It's a DOHC ZC, it's been sleeved, has SRP pistons and eagle rods. The whole assembly will be balanced. I belive the rev limit is 7200 or 7400 on a stock ZC. Also throw into the mix i have a Zdyne comp and it will be tuned before i over rev it, that's if it's safe. I'm hoping to rev to about 8,000-8200. I'd really like some opinions. Thanks
Old Jun 5, 2003 | 09:26 AM
1_bad_EF's Avatar
Default Re: Rev limit on a built motor ?? (boosted_zc)
did you upgrade the valvetrain?????? if not, dont rev past stock rev limit.
Old Jun 5, 2003 | 10:57 AM
martini's Avatar
upgrade the valvetrain (springs, retainers, valves, guides) and you could probably hit 9k with that thing.
Old Jun 5, 2003 | 11:00 AM
boosted_zc's Avatar
Default Re: Rev limit on a built motor ?? (1_bad_EF)
Well if there was valvetrain available for the ZC i would upgrade it, but there is none so i'm kinda screwed. I could send my stuff to ferrea and have them custom make it, but that's WAY to much $$$$$. I wish someone would wake up and start makin performance parts for ZC's
Old Jun 26, 2003 | 10:13 PM
MrEG6er21
Guest
Posts: n/a
I wish that were true too. One time I had wished there was an inexspensive way to modify my engine and it worked with my intake.
Old Jun 28, 2003 | 03:59 PM
boosted_zc's Avatar
Default Re: Rev limit on a built motor ?? (HNDAPJT21)
AH HA! Finally found a shop the has some experienc with ZC heads. Appearently they mod the head to fit LS valvetrain and there's aftermarket LS valetrain available. WOOPIE!! So i should be able to safely take it up to 8500-8800.....hopefully.
South Bay Surfer
12
Nov 22, 2005 08:06 AM
civais
May 20, 2004 07:01 PM
ham
73
Feb 11, 2004 05:55 AM
Hondasaurs
Jan 7, 2003 02:45 PM
