Heater removed. Cap off or loop hose?
Old Jun 6, 2003 | 04:01 PM
275Performance's Avatar
Default Heater removed. Cap off or loop hose?
I have removed my heater and A/C. Right now I just have to hose looped from the thermostat housing to the head.
Would the coolant circulation be effected much if I were to cap off both ends, elminating the hose?
Old Jun 6, 2003 | 07:53 PM
Chiovnidca's Avatar
Default Re: Heater removed. Cap off or loop hose? (275Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 275Performance &raquo;</TD></TR><TR><TD CLASS="quote">I have removed my heater and A/C. Right now I just have to hose looped from the thermostat housing to the head.
Would the coolant circulation be effected much if I were to cap off both ends, elminating the hose?</TD></TR></TABLE>
It doesn't make very much of a difference either way.
Old Jun 6, 2003 | 07:57 PM
Pat McGroin's Avatar
Default Re: Heater removed. Cap off or loop hose? (Chiovnidca)
If you cap the ends, in the long run, it will leak. If you loop it, it will last longer
Old Jun 7, 2003 | 08:05 AM
Default Re: Heater removed. Cap off or loop hose? (Pat McGroin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat McGroin &raquo;</TD></TR><TR><TD CLASS="quote">If you cap the ends, in the long run, it will leak. If you loop it, it will last longer</TD></TR></TABLE>
What would it leak over time?
Since it doesn't seem that capping will hurt anything, I was going to weld caps on to ensure complete seal.
Old Jun 7, 2003 | 08:45 AM
earl's Avatar
Welding shut the in/outlets that fed the heater should last forever with no problems
imbest123
10
Dec 8, 2010 08:15 AM
ordale
Feb 5, 2008 06:24 PM
PogKai
May 25, 2007 10:46 PM
floatfisher
Apr 20, 2007 08:32 PM
snowblind7x
Feb 21, 2007 08:58 PM
