Wheel is wobbling back and forth ???
Old Jun 6, 2003 | 06:38 PM
DEVIN22CBR's Avatar
Default Wheel is wobbling back and forth ???
So heres the problem ....When I jack my car up in the air ..I can pull back and forth on my rotor/wheel and it has a lil give to it ?? Any idea whats wrong here
Old Jun 6, 2003 | 06:40 PM
granada_sun's Avatar
Default Re: Wheel is wobbling back and forth ??? (BALL BAG)
If its the wheel that wobbles, then the lugnuts need to be removed and retightened, top, bottom, left, right....
If the wheel/rotor wobbles, probably need new rotor.
Old Jun 6, 2003 | 06:47 PM
DEVIN22CBR's Avatar
Default Re: Wheel is wobbling back and forth ??? (granada_sun)
Yea, Its def the rotor
Old Jun 6, 2003 | 07:49 PM
Chiovnidca's Avatar
Have you checked your wheel bearings, ball joints and tie rods?
Old Jun 6, 2003 | 08:07 PM
Mohudsolo's Avatar
Default Re: Wheel is wobbling back and forth ??? (Chiovnidca)
Rotors are one piece of cast iron, they don't wobble. If the lugs are tight with nothing trapped between wheel and rotor or rotor and hub, most likely bearing. Replacing a wheel bearing is not a job to tackle without access to a good press and some specialized tools. Not too hard to do with the right stuff, really hard, nearly impossible, without.
Unphzd
Dec 17, 2010 01:10 PM
e g - s i x
Apr 20, 2005 06:14 AM
CXHatchback
Oct 16, 2003 04:16 PM
Mr X
Jul 31, 2003 06:40 AM
Takeoff
Feb 23, 2003 11:11 AM
