Possible CV problem: Plz help!
Old Jun 4, 2003 | 11:14 PM
sirjeff's Avatar
Default Possible CV problem: Plz help!
Well, after doing some research ive come to the conclusion that the problem im having matches the symptoms of a bad cv joint...
heres the thing.
there isnt any visable wear on the boots... theres no axle grease or anything to be found.... could it be the intermediate shaft?? there is what looks to be motor oil dripping from the bearing or whatever it is on the intermediate shaft, but my oil pan gasket could just be a pos.
the click doesnt happen too often, so i think ive discovered it early..
if it makes a diff (probably) i was in an accident where the front end took a knock, but had no visable damage when i went into a ditch.
the car is a 00 sir (canada)
thanks much in advance for your help guys..
ive searched too.... for hours
Old Jun 4, 2003 | 11:35 PM
ill phil's Avatar
Default Re: Possible CV problem: Plz help! (sirjeff)
What kind of click, just occasional? Or steady when making a turn?
You say there is an oil of somesort by the int. shaft- is coming from where the shaft meets the tranny casing, or just on the shaft by the pan?
Old Jun 4, 2003 | 11:57 PM
poison's Avatar
Hmm. I would clean up everything from under the car, take it around for a while and inspect any leaks or any nature underneath the car.
caliskier
Apr 14, 2012 08:52 AM
Cay-DC2
Mar 21, 2011 08:40 PM
TypeRMOBBiN209
Transmission & Drivetrain
Sep 23, 2010 01:31 PM
scartail
Dec 17, 2006 03:25 PM
compprat
Honda Civic (2001 - 2005)
Jul 16, 2006 06:40 AM
