Wiring B18C
Old Jun 5, 2003 | 10:44 AM
monicle's Avatar
Default Wiring B18C
OK on a JDM B18C there is a sensor behind both the upper and lower radiator hoses on the block. What i need to know is which wires go to which? Also if you have the wire colors that would be good also. I think one is going to have a black wire and a blue wire, and the other has a black wire and a green wire. Also on a possibly related issue. After my swap my heater doesnt work. I had someone turn the temp **** in the car and I watched the actuator open and close in the engine bay but the air never heats up. Any ideas?
Old Jun 5, 2003 | 10:55 AM
1_bad_EF's Avatar
Default Re: Wiring B18C (monicle)
air bubble in cooling system?
I think it the fan switch
Old Jun 5, 2003 | 11:19 AM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">OK on a JDM B18C there is a sensor behind both the upper and lower radiator hoses on the block. What i need to know is which wires go to which? Also if you have the wire colors that would be good also. I think one is going to have a black wire and a blue wire, and the other has a black wire and a green wire. Also on a possibly related issue. After my swap my heater doesnt work. I had someone turn the temp **** in the car and I watched the actuator open and close in the engine bay but the air never heats up. Any ideas?</TD></TR></TABLE>
you need to be more specific on what your trying to describe, there's ALOT of sensors behind the upper and lower raidiator hoses.
hyper em1
Aug 29, 2009 06:31 AM
Jakester9500
Mar 6, 2007 03:21 PM
the soL that could
Apr 14, 2006 09:12 AM
monicle
Jun 5, 2003 01:24 PM
monicle
Jun 5, 2003 10:37 AM
