HELP identify my ecu setup
Old Jun 8, 2003 | 09:45 AM
Doogie Howser's Avatar
Default HELP identify my ecu setup
i bought my new car with this ecu setup and im wondering if anyone can tell me what ecu it is or how i can figure it out
thanks for the help
Old Jun 8, 2003 | 09:58 AM
mmuller's Avatar
Mad Scientist
Default Re: HELP identify my ecu setup (Doogie Howser)
it has an obd2 to obd1 conv. as far as the ecu look at the side of it, there should be #'s look at the middle one (p91,p28,p73,etc.)
Old Jun 8, 2003 | 12:50 PM
Default Re: HELP identify my ecu setup (mmuller)
is the number on a stick on the side because i didnt see any number or any sticker, also is there a way to tell by opening it?
Old Jun 8, 2003 | 01:32 PM
Kataku2K3's Avatar
Yea that's right it's an OBD2b-OBD1 jumper... It allows you to run any OBD1 ECU on a 99+ Civic or 2000+ Teg... As for the ECU open it up, you only have to unscrew the top (the end opposite the mounting pegs)... Then tell me what the numbers are... Say it's a P05/06/28 it could be one of these two boards, either the 11F0-1500 or 1720-1500 (ending digits)... Just let me know and i'll get back to ya ASAP... Peace
Old Jun 9, 2003 | 09:57 AM
Default Re: HELP identify my ecu setup (Kataku2K3)
alright i opened it up the numbers were 1720-1500 so which ecu would that be?
Old Jun 9, 2003 | 10:01 AM
Kataku2K3's Avatar
Cool, my guess is that it is a P28... Could be a P05 or P06 but they're all the same once they've been chipped... From the looks of everything you have a '99-2000 white Civic (atleast on the inside) but are you running a DOHC VTEC motor??? Peace
Old Jun 9, 2003 | 05:01 PM
yea im running a b18c block with a itr head crower valve springs and retainers and ctr cams, so right now is this ecu holding back a lot of power considering its unchipped and made for a sohc?
Old Jun 9, 2003 | 05:16 PM
Kataku2K3's Avatar
The ECU isn't chipped for DOHC VTEC??? Yea it's holding back a lot if it's still running under SOHC parameters... I would definately recommend a SK2 proggy with a 5200-5700rpm VTEC x-over... I've dealt with Mugen, Spoon, and PYR but for some reason they just don't seem to make better than average power... Get that thing chipped and you'll see what you were missing... Good Luck
Old Jun 9, 2003 | 05:49 PM
well i bought it with this ecu setup in it and i dont know if its chipped, is there any way i can tell by looking in the ecu if it is already chipped?
Old Jun 9, 2003 | 06:19 PM
Kataku2K3's Avatar
Yup, do you see any chips where I have them circled on this 1720-1500 board??? If not then you have a stock P28, if there is a 20 pin latch IC 74HC343 (the thin one) and the 28 pin ROM over the 27256 slot (the big one) then you most likely have a DOHC VTEC P28... The chips can be in place but J1 has to be jumped in order to activate the ROM...
Old Jun 9, 2003 | 06:33 PM
leadfoot78's Avatar
Look like my p28 from Kenji.
Old Jun 9, 2003 | 06:53 PM
Default Re: HELP identify my ecu setup (leadfoot78)
there are 2 chips in those places so it looks like i do have a chipped ecu, thanks for all the help and the quick feedback it is much appericated
Pimpsherm2009
Jan 13, 2010 06:05 PM
MKEK9
Feb 22, 2007 08:00 PM
eater_eg6
Dec 12, 2005 12:54 AM
AG3_Teg
Mar 29, 2005 07:18 PM
