Impending Brake Upgrade...Need Suggestions!
Old Jun 6, 2003 | 04:05 AM
Crimson490's Avatar
Default Impending Brake Upgrade...Need Suggestions!
I can feel my microscopic stock rotors are warped - i can feel it in the brake pedal and in the steering wheel when I slow down...like the brakes grip more at a certain point in the wheel's revolution. I might have a little bit of time depending on how worn down the pads are.
So, if i've got to replace the rotors, i may as well go big, baby! Problem is, I've got 15" honda rims ('03 si) and need a good kit that will fit inside.
Any suggestions?
Thanks
_________________
Old Jun 6, 2003 | 04:23 AM
vactor's Avatar
Default Re: Impending Brake Upgrade...Need Suggestions! (Crimson490)
11.1"x28mm NSX or Legend GS rotors and dual piston calipers. fits under stock 15" GSR wheels, and inexpensive to boot.
Old Jun 6, 2003 | 07:24 AM
turbochic's Avatar
Default Re: Impending Brake Upgrade...Need Suggestions! (vactor)
sometimes depending on HOW warped your rotors are you can just have them resufaced. I upgraded to brembo cross drilled/ slotted rotors and went with VGX pads, works with stock calipers and stock setup.
Old Jun 6, 2003 | 09:08 AM
Crimson490's Avatar
Default Re: Impending Brake Upgrade...Need Suggestions! (fmaxturbochic)
thank you both! I will look into these options...
Old Jun 6, 2003 | 11:08 AM
Aron Parsons's Avatar
Check to see if you can get your rotors turned (if they're within the service limit). You may not need to drop the money on a new set of rotors yet.
Also, before you think about increasing rotor size, try a fresh set of pads and fluid. You'd be amazed at how much a decent set of pads and fresh fluid will tighten up your brake system. Don't always go for the bigger solution.
MDM
21
Aug 20, 2007 09:54 PM
ITR #0202
Nov 17, 2002 08:50 AM
crewjones
Sep 29, 2002 10:59 AM
shamoo
25
May 31, 2002 09:54 PM
2000GSR
May 28, 2002 05:41 PM
