adjusting your idle
Old Jun 6, 2003 | 06:55 PM
nkato's Avatar
Default adjusting your idle
I've got a 99 civic ex SOHC, and I was wondering, if it is possible, is there a place on the engine where you can adjust how your car Idles? Please help me... thank you.
Old Jun 6, 2003 | 06:56 PM
granada_sun's Avatar
Default Re: adjusting your idle (nkato)
There should be an idle screw on the throttle body, pretty sure the top, tighten to raise, loosen to lower....if that doesn't work, adjust the throttle cable.
Old Jun 6, 2003 | 09:28 PM
blackhatchy's Avatar
Default Re: adjusting your idle (granada_sun)
where exactly is it on the 96-98 civic engines?
i cant find one at all.
Old Jun 6, 2003 | 09:34 PM
bryan305's Avatar
Default Re: adjusting your idle (blackhatchy)
should be right next to the opening on the tb. Might be covered by a little plastic/rubber plug.
Old Jun 6, 2003 | 09:35 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun &raquo;</TD></TR><TR><TD CLASS="quote">There should be an idle screw on the throttle body, pretty sure the top, tighten to raise, loosen to lower....if that doesn't work, adjust the throttle cable. </TD></TR></TABLE>
no no it's the other way around; loosen to raise the the idle, tighten to lower the idle. check the helms manual I'm 100% sure.
Old Jun 6, 2003 | 10:09 PM
bryan305's Avatar
Default Re: adjusting your idle (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">loosen to raise the the idle, tighten to lower the idle. </TD></TR></TABLE>
Correct
Old Jun 7, 2003 | 02:03 PM
Default Re: adjusting your idle (bryan305)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryan305 &raquo;</TD></TR><TR><TD CLASS="quote">should be right next to the opening on the tb. Might be covered by a little plastic/rubber plug. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryan305 &raquo;</TD></TR><TR><TD CLASS="quote">should be right next to the opening on the tb. Might be covered by a little plastic/rubber plug. </TD></TR></TABLE>
thanks
Old Jun 7, 2003 | 03:25 PM
Perfectionist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun &raquo;</TD></TR><TR><TD CLASS="quote">....if that doesn't work, adjust the throttle cable. </TD></TR></TABLE>
Never ever adjust the idle by tightening the throttle cable. You'll open a VERY fat can of worms if you do.
Old Jun 7, 2003 | 10:35 PM
ramz7887's Avatar
Default Re: adjusting your idle (Perfectionist)
You should adjust the screw on the top of the tb? how will that change the idle? When my car is cold it idles at 1500 rpm and then once is get warms up it idles at very low rps like around 200. Should i loosen the screw a little? Some people told me that my tb could be dirty that is why it idles low?
Old Jun 8, 2003 | 01:33 PM
no no it's the other way around; loosen to raise the the idle, tighten to lower the idle. check the helms manual I'm 100% sure.</TD></TR></TABLE>
well, you get the idea....
Old Jun 10, 2003 | 11:16 PM
blackeg's Avatar
Default Re: adjusting your idle (ramz7887)
my car is the same with the idle- 1500 when cold and real low when its warm. ever since i installed my header last week the idle dips real bad (tach needle moves between the little idle line right above zero and the zero line)and it almost feels like its gonna stall but it doesnt. usually happens when im at idle for a minute or 2 and then turn my steering wheel or something...im gonna mess with the idle screw tomorrow and see if i can help it out any.
BallerAccord
Mar 14, 2008 11:29 AM
631 Teggy
14
Nov 23, 2005 09:11 AM
Full Race A6
May 17, 2005 03:53 PM
FlatLineEG8
Mar 4, 2004 04:47 PM
stock97
Aug 14, 2003 10:14 PM
