Rear swaybar size
Old Jun 7, 2003 | 10:25 AM
techboy's Avatar
Default Rear swaybar size
I am building up a 94 civic cx hatch.I was wondering about getting just a rear swaybar or getting both.If i get both should the rear be larger since it is a FWD.
Thanks any help would be great
PS it is also getting a h22a in it so should I go larger yet,How big is to big
Old Jun 7, 2003 | 10:48 AM
VTEC-DA's Avatar
Default Re: Rear swaybar size (techboy)
Go with an ITR rear sway with the Beaks mounting kit.
Old Jun 7, 2003 | 12:58 PM
techboy's Avatar
Default Re: Rear swaybar size (VTEC-DA)
Still new at this ITR=Integra??
the DR.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by techboy &raquo;</TD></TR><TR><TD CLASS="quote">Still new at this ITR=Integra?? </TD></TR></TABLE>
ITR = Integra Type R
Old Jun 7, 2003 | 01:07 PM
VTEC-DA's Avatar
Default Re: Rear swaybar size (SlicedBread)
http://www.beaksproducts.com/eg-quickswap.html
Check out that link. That will have everything you need to know.
Old Jun 7, 2003 | 06:27 PM
mmuller's Avatar
Mad Scientist
or you can get the bsq mounting brackets,they are cheaper and work just as good
Old Jun 7, 2003 | 07:24 PM
DJ KrunchyKracker's Avatar
Default Re: Rear swaybar size (mmuller)
u want the front bar bigger because there is more weight up there. and the more weight the bigger the bar. the bigger the bar the stiffer the suspension
jikespingleton
Jul 16, 2006 06:55 PM
Sukii
Oct 28, 2004 03:29 PM
SlammedBlueEM2
May 28, 2003 11:21 AM
ITR#132
Nov 19, 2001 10:35 PM
keithv
Aug 8, 2001 09:30 PM
