skunk2 cams + ctr pistons
Old Jun 4, 2003 | 08:01 AM
P1mpSlap's Avatar
Default skunk2 cams + ctr pistons
If you ran CTR pistons and skunk2 cams, would the piston to valve ratio/clearance be too small and the pistons hit the valves?
Search yeilded way too many CTR results to weed through.
Anyone have this setup?
Old Jun 4, 2003 | 09:08 AM
1_bad_EF's Avatar
Default Re: skunk2 cams + ctr pistons (P1mpSlap)
while my current engine was on the engine stand, we put in crower stg 3 vtec cams in and put clay in the cylinders and checked clearance. I also have ctr pistons. Everything as far as we could see, was ok. They have huge valve reliefs in them.
Anyone else???
Old Jun 4, 2003 | 09:12 AM
P1mpSlap's Avatar
Default Re: skunk2 cams + ctr pistons (1_bad_EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_bad_EF &raquo;</TD></TR><TR><TD CLASS="quote">while my current engine was on the engine stand, we put in crower stg 3 vtec cams in and put clay in the cylinders and checked clearance. I also have ctr pistons. Everything as far as we could see, was ok. They have huge valve reliefs in them.
Anyone else???
cool beans
I totally forgot about claying the motor!!!
Still dont want to dump some money into the pistons and them not work. You are right about the valve releifs tho. They are pretty deep. I'd just hate to see my investment come to a crashing end. If you know what I mean. lol
Old Jun 4, 2003 | 09:14 AM
riceboyEFsi's Avatar
im running this setup w/ the skunk stage 2 's my motor was also clayed and i shouldnt have any problems
Old Jun 4, 2003 | 02:04 PM
granada_sun's Avatar
Default Re: skunk2 cams + ctr pistons (riceboyEFsi)
what about with skunk2 valves, where they're flat as opposed to inverted like oem valves.....
Old Jun 4, 2003 | 04:58 PM
b19coupe's Avatar
Default Re: skunk2 cams + ctr pistons (granada_sun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun &raquo;</TD></TR><TR><TD CLASS="quote">what about with skunk2 valves, where they're flat as opposed to inverted like oem valves.....</TD></TR></TABLE>
That will not change the piston to valve clearance.
Even if everybody says that they run CTR pistons with Skunk2 Stage 2 cams with no problems, I would still clay the motor. If you are going to run adjustable cam gears (as you should), clay the motor with the exhaust cam retarded as far as you think you might go, and the intake cam advanced as far as you plan on going.
Old Jun 4, 2003 | 08:09 PM
Tweakmeister's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceboyEFsi &raquo;</TD></TR><TR><TD CLASS="quote">im running this setup w/ the skunk stage 2 's my motor was also clayed and i shouldnt have any problems</TD></TR></TABLE>
what kind of power are you making?
THUNDERCHUNKY
Jul 20, 2005 11:59 AM
DualCamEK
Sep 12, 2003 09:33 PM
JD_B18CDX
Dec 1, 2002 10:32 AM
InfamousRS
Apr 20, 2002 05:09 PM
