cutting springs
Old Jun 6, 2003 | 08:10 AM
Rising sun #1's Avatar
Default cutting springs
how can i cut my spring in my beater just for shitts and giggles. can someone tell me how to cut them and ar directions
Old Jun 6, 2003 | 08:18 AM
you69's Avatar
Default Re: cutting springs (Rising sun #1)
no real secret. just cut out a coil. but be warned!!! you will lose any sence of ride or handeling you ever had in your car. it ***** up your suspension BAD!
i saw something that was suposed to 'lower' the car using stock springs without cutting basicaly what is is a set of U-bolts that go around and compress a coil or two.
Old Jun 6, 2003 | 08:23 AM
genetsang's Avatar
chill son.... dont be driving anywhere near me if you decide to cut the springs.... the only laugh and giggles that you would be getting is. if you wrap yourself around a tree...
but in al honesty.... like the guy said.. you can use "clamps" to compress a couple of the coils together.. essentially making it smaller.. but still, i think its a bad idea...
Old Jun 6, 2003 | 11:11 AM
Aron Parsons's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rising sun #1 &raquo;</TD></TR><TR><TD CLASS="quote">how can i cut my spring in my beater just for shitts and giggles. can someone tell me how to cut them and ar directions</TD></TR></TABLE>
Don't even waste the time. If you're going to be driving on the streets, it is not safe and shouldn't be done. If it's a beater, just leave it alone and drive it as is. Why would you want to make a crappy car even worse?
Old Jun 6, 2003 | 11:15 AM
tominos's Avatar
use a cutting torch, be sure to take all the pressure off the spring first by removing the spring from the strut.
Old Jun 6, 2003 | 11:19 AM
Default Re: cutting springs (Aron Parsons)
This is not my brother's 240sx so im not looking for handeling, I leave the racing at the track(a kid around here just got killed) I just whant to drop her alittle without spending any money.
Old Jun 6, 2003 | 11:20 AM
To get a slamed look how many coils should i cut! and is it Easy(1hr-?)
Old Jun 6, 2003 | 01:37 PM
ITRpwrdEG's Avatar
Cutting a few coils off is like ************. It's not as fun as getting your **** slobbed, but it's a quick job. If you have a dremel, then use a cut-off wheel and it should take about 3 min. to cut the coils off each spring. Remember, only cut a few of the Progressive coils at the top of the perch off. If you cut the bottom ones, then your shock will bottom out because there is no stiff spring left.
By eliminating too many progressive coils, your car will just not be able to absorb as many little bumps and it will compress faster to hit the stiff linear spring under the progressive ones. So you get:
1. A little stiffer ride
2. And you feel the light bumps a little more
3. It's not going to be that much more bouncy if you only take off a few coils
The best would be to cut a few coils off a sport spring, cause its not that stiff to begin with, but who knows. Just be careful and dont cut too many off. If it's a beater car, wtf, cut em. Peace
vincepru
Suspension & Brakes
12
Oct 14, 2005 10:48 AM
VIPERBLUELX
Sep 12, 2005 09:11 AM
Eibach95Civic
30
Mar 5, 2004 03:27 PM
Rising sun #1
Jun 8, 2003 04:31 PM
PnX-R
Apr 27, 2002 03:02 PM
