sohc timing question. I cant get the light to light :-)
Old Jul 14, 2003 | 05:25 PM
Sinner's Avatar
Default sohc timing question. I cant get the light to light :-)
here is what I did I hooked the red wire to the +12 on the battery and the blackwire to the ground. Then I hooked the green wire to the sparkplug wire which closest to the flywheel because I pretty sure its #1. I jumped the service connecter under the glove compartment box. When I pull the trigger and point at the flywheel nothing happens. Anyone know what I'm doing wrong?
Nick
Old Jul 14, 2003 | 05:27 PM
mmuller's Avatar
Mad Scientist
Default Re: sohc timing question. I cant get the light to light :-) (Sinner)
your hooking it up wrong....#1 is closest to crank pulley
Old Jul 14, 2003 | 05:30 PM
Sinner's Avatar
wow, I need a break. I ment crank pulley. I dont know why I said flywheel. btw It came with a long spring thing what is that?
Also its a direct hookup timming light. Its what they told me I needed.
Nick
Old Jul 14, 2003 | 05:33 PM
mmuller's Avatar
Mad Scientist
Default Re: (Sinner)
long spring thing?wha the timming light?
Old Jul 14, 2003 | 05:37 PM
Sinner's Avatar
yea it came with a long spring that reduces in size. I have know idea what it does. it is not attached to the timing light.
Old Jul 14, 2003 | 05:39 PM
mmuller's Avatar
Mad Scientist
never seen that, nothing in the directions?
maybe its bad?
Old Jul 14, 2003 | 05:41 PM
Sinner's Avatar
this is the first time i tryed setting my timming, and ive never done it before so i dont know if its a bad light or I'm doing it wrong. any way to test the light out?
Old Jul 14, 2003 | 05:47 PM
mmuller's Avatar
Mad Scientist
well, the light should have a little led that shows you if its good. what kind of light did you get?
Old Jul 14, 2003 | 06:05 PM
Sinner's Avatar
a actron 30 dollar dc power timing light.. I'm using aftermarket spark plug wires. would that do it?
Old Jul 14, 2003 | 06:25 PM
Yougod's Avatar
Make sure the you're hooking up the wire on the spark plug wire correctly. Make sure it's wrapped around the #1 spark plug wire and not clamped down on it. Other than that, as long as u have power and ground it should be working.
Sinner's Avatar
thanks I clamped it on it.
Old Jul 14, 2003 | 06:57 PM
Sinner's Avatar
I just wrap the green wire around the sparkplug wire and clamp it back on itself. correct? i wish I could find my manual.
Old Jul 14, 2003 | 07:03 PM
georgelb's Avatar
If it's not an inductive pickup timing gun then that might be what that spring is for. It might clamp on top of the spark plug and then plug into the boot and the green wire clips to that. dunno
I had an old cheap gun that worked like that
Old Jul 14, 2003 | 07:14 PM
Sinner's Avatar
does it hook directly to the spark plug wire to the spark plug or the spark plug wire and the distributor cap?
Nick
Old Jul 15, 2003 | 02:46 AM
georgelb's Avatar
Mine hooked to the plug itself, I used it on a domestic though and it was really easy to get to the plug.
I really do not know if it will make a difference hooking it up the the distributor...I wouldn't think it would. A manual would really help you out right about now. :-/
Old Jul 15, 2003 | 04:12 AM
JimBlake's Avatar
Default Re: (georgelb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgelb &raquo;</TD></TR><TR><TD CLASS="quote">If it's not an inductive pickup timing gun then that might be what that spring is for. It might clamp on top of the spark plug and then plug into the boot and the green wire clips to that. dunno
I had an old cheap gun that worked like that</TD></TR></TABLE>
Yeah, I had one like that too. You put the big end of the spring on top of the spark plug, in place of the plug wire. Then you put the plug wire onto the spring. Now you clamp the trigger wire of the light directly onto the spring. Don't loop it around & clamp to itself.
Since your plug is down in a hole in the valve cover, there might not be enough room to use that kind of light. Make sure it doesn't short to ground... Maybe you can make it fit at the distributor cap instead.
Dark_Helmet
Jan 12, 2005 05:51 AM
turbotime
Jul 5, 2003 10:40 AM
illusion
Feb 16, 2002 11:18 AM
