Signs of an worn out clutch?
Old Jul 14, 2003 | 04:38 PM
envious1320's Avatar
Default Signs of an worn out clutch?
I need to know what are some of the things to look for when it is time to get a new clutch. I think that i might need one but not quite sure. I have had the clutch since i bought the car and who knows how long it was in there before that. I just think it might be time. Also what one to get because my car is daily driver so i need it to have that oem feel but still grab better than oem.
Old Jul 14, 2003 | 05:15 PM
Katman's Avatar
Default Re: Signs of an worn out clutch? (envious1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envious1320 &raquo;</TD></TR><TR><TD CLASS="quote">I need to know what are some of the things to look for when it is time to get a new clutch. I think that i might need one but not quite sure. I have had the clutch since i bought the car and who knows how long it was in there before that. I just think it might be time. Also what one to get because my car is daily driver so i need it to have that oem feel but still grab better than oem.</TD></TR></TABLE>
a way common symptom of a dead clutch is when you're engaging the clutch, the rpm's climb, but the car seems to be going nowhere....aka clutch slippage.
Another symptom is the car will not engage any gear, this is usually pressure plate related though.
there's more symptoms, but those are the ones on the top of my dome piece.
Old Jul 14, 2003 | 06:12 PM
Default Re: Signs of an worn out clutch? (Katman)
It does have some slippage but it feels like it engaes way earlier then it use to. Also lots of play in the pedal before it actually feels like some resistance.
Old Jul 14, 2003 | 07:33 PM
Mohudsolo's Avatar
Cable or hydraulic? If cable, could just be adjustment. If it is worn out, it will slip easiest in top gear going uphill. If the revs go up and the speed does not, slippage. If it's worn that far, check the flywheel carefully for wear and get it machined properly.
Old Jul 14, 2003 | 07:46 PM
97hb's Avatar
Drive about 45mph in 5th and floor it. You will be able to tell if it is slipping. Also it has a odd smell when its slippin hard, smells like someone welding.
Old Jul 14, 2003 | 08:38 PM
Default Re: Signs of an worn out clutch? (Mohudsolo)
I have a 96 gsr if that helps
Old Jul 14, 2003 | 09:39 PM
RangerDan's Avatar
Honda tech in town told me to put it in fifth gear and get the revs up (3500 rpm) then slowy release the clutch.
If it dies the clutch is still good...if it trys to go then the clutch is no good.
Old Jul 15, 2003 | 01:07 AM
blah13's Avatar
Default Re: Signs of an worn out clutch? (RangerDan)
For a replacement clutch look into most stage 1 clutch kits. Most offer 30-50% greater gripping capacity than stock for about $100 more than a stock one.
moz92
Transmission & Drivetrain
Apr 4, 2011 06:56 AM
theazndog
Aug 17, 2009 04:02 PM
flip888
Feb 20, 2009 05:29 PM
prelude_93vtec
Oct 14, 2007 02:12 AM
98GSRDC2
Jul 8, 2006 05:12 PM
