Advise on tunning Jun 3 with high compression.
Old Jul 12, 2003 | 05:20 PM
Mr. Lonely JDM 4dr teg's Avatar
Default Advise on tunning Jun 3 with high compression.
Can anyone with jun 3 setup help me out on my tunning.
Here is what i got
Jun 3 cams
ITR HEAD with Web valvetrain
ITR valves
GSr block with
JDM ITR pistons
ITR rods
and GSR crank
Stock GSR flywheel
Compression is at 11:6:1
Right now VTEC hits at 5700
I also got FPR and a Apexi VAFC
ECU right now is OBD II USDM ITR ECU
Im not going to rev past 9000 but rev limit is at 8700
Im open to everything. If there is a better ecu that you think i should run on then lmk. Thanks guys. oh and this if more of a all around driving car. Its going to be my daily driven car.
Modified by 96 GSR BOY at 6:33 PM 7/12/2003
Old Jul 12, 2003 | 10:09 PM
HRTuning's Avatar
Default Re: Advise on tunning Jun 3 with high compression. (96 GSR BOY)
That ECU actually has pretty decent ignition maps for what you're running... Get yourself a wideband to tune out the fuel with the VAFC or get someone to tune it for you... Good luck on your setup man... Sounds sweet...
Old Jul 13, 2003 | 07:15 PM
up
D-Rob
May 10, 2005 12:59 PM
Doubledeala
Oct 14, 2004 06:47 PM
1 speedstar
Aug 14, 2002 08:21 PM
DocV
Jul 7, 2002 06:39 PM
VoltageLS
Mar 21, 2002 10:41 AM
