TYPE R LSD in LS TRANNY
Old May 13, 2005 | 07:48 AM
SPOOLINmatt's Avatar
Default TYPE R LSD in LS TRANNY
can i put a ITR LSD in my LS TRANNY. what is needed if i can?
Old May 13, 2005 | 04:02 PM
Default Re: TYPE R LSD in LS TRANNY (SP00LIN)
bump
Old May 14, 2005 | 01:16 PM
ttt
Old May 14, 2005 | 01:37 PM
Dogginator's Avatar
Daisy... Daisy...
I'm guessing no since ATS doesn't make a differential for an LS transmission. You can ask them if their GSR/ITR differential would work in your transmission.
http://www.a-t-s-usa.com/ats-p...a.htm
Old May 14, 2005 | 05:22 PM
Default Re: TYPE R LSD in LS TRANNY (Dogginator)
wtf is ATS
Old May 14, 2005 | 05:32 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00LIN &raquo;</TD></TR><TR><TD CLASS="quote">wtf is ATS</TD></TR></TABLE>
Did you click the link? They manufacture aftermarket LSD for several Japanese brands. They can answer your question.
Old May 14, 2005 | 06:05 PM
ludedeg's Avatar
large 4.4. ring gear
Old May 14, 2005 | 08:49 PM
Default Re: (ludedeg)
i dont know much about tranny's but im not really a newb though. im talking about installing an OEM integra type R lsd, not an aftermarket one. one i can pickup for like 350$
Old May 14, 2005 | 09:17 PM
Takumi Fujiwara's Avatar
Default Re: (SP00LIN)
It doesn't fit without modifcation.
Old May 15, 2005 | 05:17 AM
Dogginator's Avatar
Daisy... Daisy...
The reason that I provided the link is that if the aftermarket unit can replace the stock ITR one but it will not fit the LS transmission then the stock ITR one will not fit the LS transmission.
Old May 15, 2005 | 05:31 PM
ludedeg's Avatar
Just get a large 4.4 ring gear for the diff from a gsr or u.s. spec type r transmission. Thats all you need
Old May 15, 2005 | 08:49 PM
hrmm, that ring gear will go on the lsd and then go into my tranny. ??
Old May 15, 2005 | 08:55 PM
B20luda's Avatar
i put a type R lsd in my D2a4 tranny with mods..all i had to do is make a custom shim for the dif bearings..and shave the case a lil bit when the cv joint comes thru..i dont see why u couldnt do it in an LS tranny...BTW d2a4 is a 90-91 honda prelude SI tranny
Old May 16, 2005 | 04:06 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (B20luda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20luda &raquo;</TD></TR><TR><TD CLASS="quote">i put a type R lsd in my D2a4 tranny with mods..all i had to do is make a custom shim for the dif bearings..and shave the case a lil bit when the cv joint comes thru..i dont see why u couldnt do it in an LS tranny...BTW d2a4 is a 90-91 honda prelude SI tranny</TD></TR></TABLE>
Unless he has free machining, it would be far cheaper and more reliable to just buy an ITR transmission or a GSR transmission and swap in the ITR LSD. They will directly swap to his LS, plus he would gain better gear ratios.
Old May 19, 2005 | 09:15 AM
ludedeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00LIN &raquo;</TD></TR><TR><TD CLASS="quote">hrmm, that ring gear will go on the lsd and then go into my tranny. ??</TD></TR></TABLE>
Yep
Old May 19, 2005 | 12:42 PM
95lstegman's Avatar
i use a GSR countershaft AND ring gear. it's my experience that sometimes a countershaft only likes it's original ring gear. another identical countershaft may not spin properly on a given ring gear, where the original would spin right. total parts cost $150 in a pinch for countershaft and ring gear.
HondaAddict91
Transmission & Drivetrain
14
Jan 9, 2017 07:11 PM
93b16CivicSi
Aug 16, 2005 05:36 PM
Mr.DC2TurBo
Aug 30, 2004 05:35 PM
Must be VTEC
Nov 23, 2003 10:43 PM
p1ccoloz
May 3, 2003 10:12 PM
