what do i need to know before getting rod and main bearings??
Old May 12, 2005 | 08:59 AM
rocket_R's Avatar
Default what do i need to know before getting rod and main bearings??
i'm rebuilding my h22 with new rods and had me crank balance. i alos had the machine shop that balance the crank check the rod clearance and they said that the oem rod bearings will be be good to use with my crower rods. my question is that when i order the bearings, can i just tell them which engine i need them them for and get the right bearings?? if not what do i need to know?? i'm getting honda bearings.
Old May 12, 2005 | 03:48 PM
markdman's Avatar
ok, when putting in new rod bearings, always check your clearances. Its a good idea to do this because spinning a rod blows. how do you do this? torque your end caps down to spec with the bearings installed. use plastigue between the main journal and the bearing. un torque the bolts and use the included guage to measure your clearance. should be around ~.015 on an inch.
Old May 12, 2005 | 04:12 PM
DeadVet's Avatar
Default Re: (markdman)
What do you do if the clearances are off?
Old May 12, 2005 | 04:13 PM
colombian linx's Avatar
or instead of plastigage you could also use a feeler gauge just my .02 cents,also if the main caps are aligned and bored properly and the clearance is off you could get oversized bearings if the clearance is to great or undersized bearings it the clearance is to small
Old May 13, 2005 | 09:19 AM
rocket_R's Avatar
Default Re: (colombian linx)
still havn't answer my questions. the clearance are in spec from what i was told from the machine guy, so do i just go and order it for a h22 or do i need to know number codes or something???
95hondasedan
Nov 17, 2014 07:45 AM
jakscivic
Feb 21, 2013 08:27 AM
sixtodc4
Jan 20, 2008 09:33 AM
r1de4life
Oct 23, 2007 06:40 PM
