MSD Blaster 2 leaking oil ?
Old May 8, 2005 | 05:35 PM
86si's Avatar
Default MSD Blaster 2 leaking oil ?
sounds crazy but i noticed oil coming out of the coil. anyone ever see this ?
Old May 9, 2005 | 02:22 AM
86si's Avatar
Default Re: MSD Blaster 2 leaking oil ? (86si)
WTF ?
Old May 9, 2005 | 06:30 AM
tgreaves's Avatar
That is kinda crazy.. The coil should be a completely sealed waterproof unit..
Old May 9, 2005 | 08:18 AM
bounty359's Avatar
Default Re: MSD Blaster 2 leaking oil ? (tgreaves)
dude you can get a msd ss coil for 50 bucks if your coil is leaking oil????? get a new one
Old May 9, 2005 | 09:00 AM
jdmcrx34's Avatar
yes i they aren't mounted correctly they will start to leak.i have to replace mine today also, cause i did not fill like mounting like i should have, after awhile the vibrations will cause the casing to crack.
Old May 9, 2005 | 09:53 AM
86si's Avatar
Default Re: MSD Blaster 2 leaking oil ? (bounty359)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bounty359 &raquo;</TD></TR><TR><TD CLASS="quote">dude you can get a msd ss coil for 50 bucks if your coil is leaking oil????? get a new one</TD></TR></TABLE>i'm not concerned about cost just wanted to know why.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx34 &raquo;</TD></TR><TR><TD CLASS="quote">yes i they aren't mounted correctly they will start to leak.i have to replace mine today also, cause i did not fill like mounting like i should have, after awhile the vibrations will cause the casing to crack.</TD></TR></TABLE>how should it be mounted. mine sits on its side
Old May 10, 2005 | 08:01 PM
jdmcrx34's Avatar
the shop owner that sold me mine said it should be straight up and down. also has any body had starting problems with there msd.last night my car would not start so i had somebody else crank it over and i noticed that the top of the coil and the negative post were arching like crazy, so i had to put electrical tape to get it home wile it was bucking on me the whole time.
Old May 21, 2005 | 09:57 PM
dunkd's Avatar
uhhhh, wtf, i would call msd directly
Old May 22, 2005 | 08:53 AM
turtle-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">sounds crazy but i noticed oil coming out of the coil. anyone ever see this ?</TD></TR></TABLE>
The coil is filled will oil to act as an cooling agent and dampener for vibrations.
Old May 22, 2005 | 09:15 AM
dunkd's Avatar
but what causes this to happen? I have mine mounted a little awkward...
Old May 24, 2005 | 09:16 PM
turtle-eg's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">but what causes this to happen? I have mine mounted a little awkward...</TD></TR></TABLE>
It's a sealed unit.... when it leaks, it's time to replace it. If it's good, you can even mount it upside down if you like, mines is mounted at 90degree angle.
CW96
Sep 9, 2007 06:37 AM
crazyc@SRTmotorsports
Mar 12, 2007 03:14 AM
DC2 Mang
Apr 14, 2006 11:09 PM
TurboTeG4
Jul 23, 2005 07:58 PM
1.8T_EG
May 14, 2003 09:45 AM
