Running Rich!!!!!P0172 or code 45!
Old May 6, 2005 | 12:36 PM
brnyrdcmndo's Avatar
Default Running Rich!!!!!P0172 or code 45!
I was throwing code P0140, SHO2S heater circuit malfunction. Installed a KTeller o2 sim, & universal o2. After this car threw another code. A P0172 or code 45. Fuel system running rich. What would cause this? Are the two related? I thought a secondary o2 would not effect the a/f ratio. Also, I replaced spark plugs, wires, distributor, fuel pump, fuel filter & evap purge control solenoid valve. Fuel pressure is within spec. What could be causing my problem? Please help, need to pass smog ASAP!
Old May 6, 2005 | 01:02 PM
EE_Chris's Avatar
Default Re: Running Rich!!!!!P0172 or code 45! (brnyrdcmndo)
As the code states, you're running rich. The O2 sensor is reporting to the ECU a high voltage (instead of swinging back and forth). The ECU tried to correct this and when it uses up all of its adjustment, you got the code.
So you're either running rich or the O2 is duffed.
Old May 31, 2005 | 11:20 AM
Default Re: Running Rich!!!!!P0172 or code 45! (EE_Chris)
Still running rich & throwing code P0172. I replaced the injectors & installed a VAFC2 since last post. Took it to the dyno and had it tuned (on old injectors). Everything with the fuel system has been replaced. What the hell is making it run so rich it throws a code. Would a plugged cat cause this? Any ideas?
Old May 31, 2005 | 01:20 PM
Forgot to mention I also replaced the PCV valve.
Old May 31, 2005 | 03:45 PM
Chiovnidca's Avatar
Have you tested your primary o2 sensor? It could be biased rich.
Old Jun 1, 2005 | 11:50 AM
Default Re: Running Rich!!!!!P0172 or code 45! (Chiovnidca)
The sensor is brand new it should be good. How would I go about testing it to make sure?
Old Jun 1, 2005 | 12:49 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
what mods do you have? is the fuel system all stock? you did put the 02 sim on the secondary sensor right?
Old Jun 1, 2005 | 01:10 PM
Default Re: Running Rich!!!!!P0172 or code 45! (2000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi &raquo;</TD></TR><TR><TD CLASS="quote">what mods do you have? is the fuel system all stock? you did put the 02 sim on the secondary sensor right?</TD></TR></TABLE>
The fuel system is all stock (brand new fuel pump, filter, injectors, PCV valve). Installed test pipe, new stock thermostat (had worthless Mugen). yes, o2 sim is installed on the correct sensor.
All out of ideas!
Old Jun 1, 2005 | 01:16 PM
2000psi's Avatar
Which 02 sensor did you replace with the "universal 02"? That sensor might not have the correct range the Honda ECM is looking for.
Old Jun 1, 2005 | 01:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi &raquo;</TD></TR><TR><TD CLASS="quote">Which 02 sensor did you replace with the "universal 02"? That sensor might not have the correct range the Honda ECM is looking for.</TD></TR></TABLE>
The primary! Is there a way to test it?
Old Jun 1, 2005 | 02:21 PM
2000psi's Avatar
Get an OEM 02 sensor...don't skimp on something so important like the primary 02, the difference in gas mileage alone will pay for itself in a few months vs an offbrand 02.
Old Jun 1, 2005 | 02:24 PM
2000psi's Avatar
you could always test it by installing a wideband and seeing if you really are running rich or if it's just the sensor....but thats neither here nor there. good luck
Old Jun 1, 2005 | 02:27 PM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brnyrdcmndo &raquo;</TD></TR><TR><TD CLASS="quote">Please help, need to pass smog ASAP!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brnyrdcmndo &raquo;</TD></TR><TR><TD CLASS="quote">Installed test pipe....</TD></TR></TABLE>
How about you go back to stock for the time being to pass smog??
Old Jun 1, 2005 | 03:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">
How about you go back to stock for the time being to pass smog??</TD></TR></TABLE>
The testpipe won't make a difference as there is no 2nd o2 sensor because I'm running an o2 sim. The car is OBD2 so they don't sniff it, just check the computer.
Old Jun 1, 2005 | 03:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi &raquo;</TD></TR><TR><TD CLASS="quote">you could always test it by installing a wideband and seeing if you really are running rich or if it's just the sensor....but thats neither here nor there. good luck</TD></TR></TABLE>
I have a wideband installed, and yes it shows I am running rich.
Old Jun 1, 2005 | 03:33 PM
2000psi's Avatar
how does it drive? all I can think of is that you have a leaking injector(s) since thats the only thing not replaced.
Old Jun 1, 2005 | 03:55 PM
Nope! All injectors were replaced.
Old Jun 1, 2005 | 05:29 PM
Chiovnidca's Avatar
Have you checked your fuel presure? What year and model is the car?
Old Jun 1, 2005 | 06:37 PM
HondaHemp's Avatar
You can test the 02 sensor by measuring the millivolts it produces with a voltmeter on the high and low reference wires from the sensor. 1000mv = rich, 100mv=lean. 450mv is stoitchiometric which is the perfect air fuel ratio, 14.7-1.
xtegx
Mar 19, 2010 12:39 PM
91ef_ls
Nov 15, 2006 06:15 AM
PhilStubbs
Jan 22, 2005 11:20 AM
Mr. 1582
Nov 7, 2003 03:32 PM
Turbohatch
Sep 12, 2001 10:56 AM
