Cooling fan problems - please help
Old May 30, 2002 | 03:33 PM
HX_Guy's Avatar
Default Cooling fan problems - please help
The car is overheating, and I think its due to the fact the cooling fan isnt coming on.
I have tested the fan with a direct link to the battey and it does work - so the fan is good.
The fan does NOT come on when I turn the AC on...so its not a bad fan switch (sensor) on the thermostat (unless that controls the fan when the AC is turned on also..I assume that is only for when teh car gets hot?)
The cooling fan fuse is good.
The only other link I can think of is the cooling fan relay. I dont know how to check it, how do I go about checking the relay? Im also going to try and use another replay from a different component and see if it works.
Old May 30, 2002 | 05:24 PM
Padronis's Avatar
Default Re: Cooling fan problems - please help (HX_Guy)
I checked mine by switching the 2 different relays around. If you have a multi-meter, take the relay out and look at relay with the clip facing up. "A" post is top right, "B" post is bottom right, "C" postis top left, "D" post is bottom left. With the battery connected between "C" and "D", you should get continuity between "A" and "B". There should be no continuity between "A" and "B" when the battery is not connected. This is what my helm's manual says. HTH
Old May 30, 2002 | 05:46 PM
HX_Guy's Avatar
Default Re: Cooling fan problems - please help (G2LSS)
I switched the relay arund wit ha different one (condenser fan) and the condenser fan worked, the cooling still didnt
I also tried jumping the fan switch and it didnt come on...I am freaking lost
Old May 30, 2002 | 06:11 PM
Padronis's Avatar
I'm not sure how the civic is, but my car has 3 relays. One for the condenser fan, one for the radiator fan, one for the compressor clutch. Maybe you switched the "wrong" ones? I am almost baffled.
[Modified by G2LSS, 9:33 PM 5/30/2002]
Old May 30, 2002 | 06:18 PM
jetdriven's Avatar
read my reply in the "integra" forum. its your cooling fan switch in the back of the block, next to the oil filter.
19 crx 89
10
Aug 26, 2010 12:38 PM
josemt
Jun 23, 2010 06:24 AM
Jonathan_ED3
Sep 27, 2008 10:11 AM
HX_Guy
May 31, 2002 08:38 AM
