Rebuilding engine. Nitrous Oxide help??
Old May 27, 2002 | 11:48 PM
IdotheSHOCKER's Avatar
Default Rebuilding engine. Nitrous Oxide help??
Since I am rebuilding the engine, I've decided that I want to run some nitrous oxide, just enough to squeeze on the track and to keep it safe.
So what all needs to be prepped and looked at before I begin to squeeze.
My engine is a B18C1 GSR.
As dumb as this might sound I wanted to hook it up to something smaller than a 10 lb bottle, do they exist?
Old May 27, 2002 | 11:56 PM
Kamin's Avatar
Default Re: Rebuilding engine. Nitrous Oxide help?? (EGB18hatch)
how much of a shot do you want to run
Old May 28, 2002 | 12:00 AM
jdmjunkie's Avatar
NOS bottle sizes range from 10oz, 1lbs., 2lbs., 2.5lbs., 5lbs., 10lbs., 15lbs., and 20lbs.
I don't like bringing it up and I'm sorry I had to but if you watch F&F the 10oz sneaker shots are in the "10 sec" seven.
if you want to squeeze make sure to have nitrous/turbo pistons. stock cast pistons have the habit of melting in response to burning nitrous. most importantly back the system up with fuel.
Old May 28, 2002 | 12:02 AM
Default Re: Rebuilding engine. Nitrous Oxide help?? (KAMiN)
Is it true that the amount should be 50% of your hp rating? The GSR makes 170 HP not WHP of course.
I think a 50 shot will be more than fine with the GSR you think?
Also is there a bottle smaller than those 10lb ones? Where can you get them, cant find on net or NOS website.... yeah I was thinking someone might mention the F&F but oh well
Also what company or kind of pistons are good to run... lower compression ones??
[Modified by EGB18hatch, 9:03 AM 5/28/2002]
[Modified by EGB18hatch, 9:04 AM 5/28/2002]
Old May 28, 2002 | 12:06 AM
jdmjunkie's Avatar
look up also the 40-60 shot kit from NOS (part #05122) is most likely what everyone gets. NOS also has the intake plate for GSR's which make installation easy and clean.
Old May 28, 2002 | 12:08 AM
jdmjunkie's Avatar
Default Re: Rebuilding engine. Nitrous Oxide help?? (jdmjunkie)
here you go http://www.nosnitrous.com/HiOctn/Pro...S/imports.html
pistons are made by all the big boys for this ap. Arias, JE, SRP, E.N.D.Y.N., ROSS, etc.. you name em they got a nitrous ap. if you are interested in a kit I can get you one.
Old May 28, 2002 | 12:10 AM
Im not sure what all I need to do to protect my engine.... like stainless steel valves and etc. I dont know.... a 50 shot should be safe??
Old May 28, 2002 | 12:11 AM
jdmjunkie's Avatar
yes if put together right and with the right motor setup it's stable.
Old May 28, 2002 | 12:13 AM
What exactly is that.... sits on the manifold?
Nitrous noobie sorry
[Modified by EGB18hatch, 9:14 AM 5/28/2002]
Old May 28, 2002 | 12:38 PM
EVOCELICA's Avatar
New User
it sits between the manifold and the head and has spray bars it's similar to a direct port system with out having to drill the mani.
lazyxmofo
May 12, 2008 03:02 AM
The7thG
Honda Civic (2001 - 2005)
Feb 4, 2007 08:05 PM
acc97lxAndy
Sep 6, 2003 09:00 AM
exquivical
Jun 30, 2002 01:12 AM
2K1_ITR
Jun 23, 2001 04:35 PM
