Help! EF Si fuel/ecu/electrical problems
Old May 29, 2002 | 08:45 AM
sackdz's Avatar
Default Help! EF Si fuel/ecu/electrical problems
Okay my '89 Si hatback won't start up. It turns over, spark on all 4 cylinders, but it won't start. This was a problem that occured every once in a while but it would start after waiting a few minutes or a day. Well it's been stuck now for 4 or 5 days, still cranking but won't fire up.
I need to know what exactly the problem is. Someone before said a bad relay. Anyways, it's at work so I don't have all my tools, but do have access to a multimeter.
I'm pretty sure it's an electric problem, but I don't know where to look.
Voltage on fuel pump was ~6-7V. Doesn't it run on 12V? Is it the harness right under the front edge of middle of the backseat?
Where is the ECU located? I can't see it, is it under the large plate in the passenger footwell? What fuse is the ECU on?(Not the backup power).
TIA
Old May 29, 2002 | 02:47 PM
sackdz's Avatar
Default Re: Help! EF Si fuel/ecu/electrical problems (sackdz)
ttt
Old May 30, 2002 | 04:02 AM
sackdz's Avatar
Smart people where are you?
Old May 31, 2002 | 07:40 AM
sackdz's Avatar
ttt
bare
15
Aug 13, 2005 06:23 PM
smokingredhatch
11
Jun 22, 2005 05:53 AM
Fototek7
Jul 27, 2002 01:59 PM
sackdz
18
Jun 3, 2002 11:02 AM
