Inside of my broken tranny
Old May 30, 2002 | 01:37 AM
CivicEx95's Avatar
Default Inside of my broken tranny
I don't know if you caught my other post, but I messed up my differential and tranny pretty good when drag racing at the track last week. It sucked. Finally took it out and apart, and here's what I found...
First off, me showing my appreciation for my tranny
Metal pieces all over the place. Notice the broken part of the case on the right side. Stupid question, but can I use this case in the rebuild?
Inside the differential. Notice the pinion gears have almost all the teeth gone and the side gear having a big chunk out of it.
With all that said. WTF happened!?! Was it just one too many 6K RPM launches that killed it? I'm seriously thinking of giving up drag racing if this is the **** I'm going to have to go through every few trips to the track.
Old May 30, 2002 | 01:46 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Inside of my broken tranny (CivicEx95)
those spider gears are CAST iron, not machined steel.
Pretty normal damage, but your tranny case is trashed. You might be able to swap the gear cluster into another tranny.
Get a Kaaz/Quaife or else get used to tranny carnage. I blew two diffs with D15 power and slicks.
BTW from the pics of tranny, it had never been apart since leaving the factory. The Hondabond gives it away.
Old May 30, 2002 | 02:58 AM
Chiovnidca's Avatar
Default Re: Inside of my broken tranny (Mista Bone)
How do you figure that? Aren't you supposed to use Hondabond to seal the cases after rebuilding? I do.
Old May 30, 2002 | 04:08 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Inside of my broken tranny (Chiovnidca)
tear apart twenty trannys and you know what 4 to 14 year old dried up HB looks like.
Old May 30, 2002 | 08:02 AM
92sleepR's Avatar
New User
You can buy a new case from Manchester Honda http://www.hondaautomotiveparts.com/
I would highly recommend a Quiafe if you plan on putting that much strain on your trans. Also, while you have the trans appart is a good time to check/replace your synchros.
Trannys are fun!
Mike
Old May 30, 2002 | 11:45 AM
CivicEx95's Avatar
Default Re: Inside of my broken tranny (92sleepR)
Is the tranny case for a DOHC del sol the same as this GSR tranny?
Old May 30, 2002 | 04:15 PM
JV's Avatar
JV
Who?
Try this........... http://www.acuraautomotiveparts.net/
Old May 31, 2002 | 03:32 PM
ee-gsr's Avatar
so that's just the stock, open differential right CivicEx95?
Old May 31, 2002 | 05:54 PM
hatchmobile's Avatar
i'll sell you my complete b16 trans w/ gears for $300...third gear is trashed, but all other gears are fine
Old Jun 1, 2002 | 02:05 AM
CivicEx95's Avatar
Default Re: Inside of my broken tranny (ee-gsr)
Yep, just stock parts in there
and ee-gsr, would you sell just the tranny case and differential?
[Modified by CivicEx95, 3:09 AM 6/1/2002]
Old Jun 1, 2002 | 03:44 PM
make me an offer and we can talk. i sent you a pm too
Old Jun 1, 2002 | 05:21 PM
AzG35's Avatar
Default Re: Inside of my broken tranny (hatchmobile)
Hmm, that looks like mine a while back ago. Definately go with an LSD if you are still wanting to race the car. It will make a huge difference. When you put it back together, make sure you clean all the parts up. There will be many metal particles inside the trees and between the gears/synchros. I had to open mine back up due to metal floating around and killing my 5th gear synchro.
aeenox
Honda Civic (2006 - 2015)
Jan 14, 2008 03:41 PM
20_00_lude
Jun 26, 2006 07:26 PM
SilverDc2
May 31, 2005 02:50 PM
Panda-san
Jun 5, 2004 05:40 PM
D16A6Turbo
Dec 12, 2002 06:17 PM
