engine is making a tapping noise
Old May 29, 2002 | 09:54 PM
carcala's Avatar
Default engine is making a tapping noise
my engine makes a tapping noise like a the valves need adjusting but i adjusted them way too many times and i still hear it. I heard that it could be the injectors cause it sounds like its coming from there. If it is the injectors why is it making this noise and what can i do to fix it? Let me know what you guys think cause im getting irritated with the tapping. its really loud and can hear it from inside my car.
Old May 29, 2002 | 09:55 PM
Tweakmeister's Avatar
Default Re: engine is making a tapping noise (carcala)
Could be injectors or valves. Also could be distributor or some bearings somewhere. Also could be something loose somewhere. Unless you have a recording it's kind of hard to tell.
Old May 29, 2002 | 09:56 PM
poison's Avatar
Default Re: engine is making a tapping noise (Tweakmeister)
Old May 29, 2002 | 10:00 PM
carcala's Avatar
Default Re: engine is making a tapping noise (poison)
sounds like the valves when they tap like they need to be adjusted but i adjust the valves already and its not it. sound is coming from the top not botoom.
[Modified by carcala, 7:01 AM 5/30/2002]
Old May 29, 2002 | 10:03 PM
aeolus's Avatar
did you have your head recently worked on???
Old May 29, 2002 | 10:06 PM
carcala's Avatar
Default Re: engine is making a tapping noise (aeolus)
nope stock head!
Old May 29, 2002 | 10:54 PM
aeolus's Avatar
check your belt tension.If not,it could be piston slap.
[Modified by aeolus, 7:56 AM 5/30/2002]
Spody02
11
Jan 8, 2009 07:02 PM
mikeunreal2
Apr 21, 2006 10:15 PM
Mr.DC2TurBo
Sep 25, 2003 09:51 PM
MKX-R
Jul 9, 2003 12:54 PM
yellowbuffalo
Apr 11, 2002 09:08 PM
