Oil on spark plug cylinder 4
Old May 30, 2002 | 03:03 PM
93SSPHatch's Avatar
Default Oil on spark plug cylinder 4
When I pulled the old plug out. . .it had oil all over it. This was the only plug that was like this. . .what could this be?
[Modified by 93SSPHatch, 5:05 PM 5/30/2002]
Old May 30, 2002 | 05:13 PM
Rocket's Avatar
Default Re: Oil on spark plug cylinder 4 (93SSPHatch)
Could be just a bad sparkplug hole vavle cover seal. Check piston top with flashlight to see if the other cylinders look any different.
Old May 30, 2002 | 05:49 PM
976's Avatar
976
New User
Default Re: Oil on spark plug cylinder 4 (Rocket)
Oil below the thread - I feel bad for ya'.
Oil above the thread, change yo valve spark plug gasket - less than a 10 10 220. Well, I guess you might want to change your valve cover gasket since you will be opening it up, might as well replace em' all above head...
ducsaim
Apr 15, 2020 09:10 PM
Jbur074
12
Dec 10, 2007 11:00 PM
Saki
Mar 4, 2005 06:20 PM
hondaracing1on12004
Dec 13, 2004 02:05 PM
screech
Jul 13, 2003 12:44 PM
