Real Tech Dudes
Old May 30, 2002 | 02:00 PM
Mikey3000's Avatar
Default Real Tech Dudes
Car: 92 Civic CX
Motor: 95 H22A
Problem: The motor will start for about 2 seconds and then die. I'm getting an MIL code 10 (IAT) and 22 (VTEC Oil Pressure Switch). the car should run regardless of these two problems. One time, the car started and stayed on for about 10 seconds and prolly would've stayed on longer but i turned it off myself because of a fuel leak at an injector (now there are no leaks). Also, i do not have an injector resistor box in. Obviously it isn't needed for the car to start though. Is it true that running w/o a resistor box could ruin the ECM? I'm using a 95 JDM M/T ECM and stock H22 injectors.
Anyone have any ideas?
Edit: Oh yeah, when i give it throttle, it falls on it's face harder than if i don't give it throttle. I know it's getting fuel at the injectors and i'm getting 40 psi at the fuel filter.
[Modified by Boss Hogg, 6:01 PM 5/30/2002]
Old May 30, 2002 | 02:12 PM
sgT's Avatar
sgT
Default Re: Real Tech Dudes (Boss Hogg)
check to make sure the IACV is connnected, and that the map/tps arent switched
regarding the resistor box, if you are using peak hold injectors with no resistors
then you WILL burn out the drivers in the ECU.
Old May 30, 2002 | 02:21 PM
Mikey3000's Avatar
Default Re: Real Tech Dudes (sgT)
regarding the resistor box, if you are using peak hold injectors with no resistors then you WILL burn out the drivers in the ECU.
how long does this take to happen?
Old May 30, 2002 | 02:26 PM
sgT's Avatar
sgT
depends.
generally not long
MantisX
Engine Management and Tuning
May 20, 2010 04:24 PM
turbojdmhatch
Jun 9, 2009 09:36 PM
mattm868
Jul 12, 2007 07:45 AM
honda9369
Sep 14, 2004 10:16 AM
Hybrid
May 26, 2003 09:20 AM
