Changing plugs while engine is hot: Ok to do or bad practice?
Old May 27, 2002 | 02:35 PM
LS-G's Avatar
Default Online Poll>>>Changing plugs while engine is hot: Ok to do or bad practice?
What do you guys think and why?? Thanks for your participation.
[Modified by LS-G, 11:38 PM 5/27/2002]
Old May 27, 2002 | 03:32 PM
dirtySOHC's's Avatar
Default Re: Online Poll>>>Changing plugs while engine is hot: Ok to do or bad practice? (LS-G)
i was also thinkin the same thing
Old May 27, 2002 | 03:38 PM
NismoNX's Avatar
Default Re: Online Poll>>>Changing plugs while engine is hot: Ok to do or bad practice? (dirtySOHC'
Do it while its hot, and use an impact gun to make sure that they are in their good.
Old May 27, 2002 | 04:18 PM
LS-G's Avatar
make sure there are in "THEIR" good, huh, nismofo? don't you mean "THERE"? I'd rather not know much about engine and be willing to learn instead of being ILLITERATE.
[Modified by LS-G, 1:19 AM 5/28/2002]
Old May 27, 2002 | 04:49 PM
dmotoguy's Avatar
i wouldnt reccomend using an impact gun to put them in.... they need to be torqued down to a certian point... the other thing is that they are really hot when the car has been running
Old May 27, 2002 | 04:51 PM
NismoNX's Avatar
It was a joke. HA HA Damn.
Old May 27, 2002 | 06:22 PM
non-VTEC's Avatar
you can change them while the engine is warm........just make sure you use a proper torque wrench to torque them down to proper spec. (13ft/lbs i belive)
the aluminium threads in the head get soft when it's hot so you have to be carful with them.
Old May 27, 2002 | 10:23 PM
jdmjunkie's Avatar
Default Re: Online Poll>>>Changing plugs while engine is hot: Ok to do or bad practice? (non-VTEC)
I wouldn't change them while they're hot because heat expansion and torque specs go hand in hand. but if you must make sure to use some high temp anti-seize.
Old May 28, 2002 | 03:18 AM
tinkerbell's Avatar
it's OK - i got it
Old May 28, 2002 | 09:15 AM
EE_Chris's Avatar
I voted "wait till its cool". However, I typically just wait until I can keep my hand on top of the valve cover for it to be 'cool'.
What do people do at a race? If they remove them, do they wait till things are cool....I'd be inclined to say no. But I'm sure they don't torque them back to factory spec while its still hot either.
Old May 28, 2002 | 11:05 AM
b18bvtec4drteg's Avatar
shouldnt do it... Aluminum head expands when hot...
Old May 28, 2002 | 11:24 PM
LS-G's Avatar
Default Re: Online Poll>>>Changing plugs while engine is hot: Ok to do or bad practice? (b18bvtec4d
i vote NO, wait for it to cool down. i'm just impatient.
Old May 28, 2002 | 11:53 PM
irev210's Avatar
stupid to do while hot
alum has a very low melting point, its much softer when its warm, much easier to strip.
do what u wish tho
Mooneyes13
Welding / Fabrication
25
Dec 9, 2005 11:11 PM
sivik2nr
Oct 21, 2002 09:31 PM
GruvyTune
Sep 25, 2002 07:02 AM
LS-G
May 27, 2002 04:33 PM
Red Rocket
Mar 29, 2002 08:31 PM
