Electrical Oil Pressure Gauge - HELP!
Old May 30, 2002 | 07:55 PM
Random.Hero's Avatar
Default Electrical Oil Pressure Gauge - HELP!
I recently bought an Autometer electrical oil pressure gauge and I am having problems fitting the sending unit into the block. The unit rubs against the oil filter and will not fit in the block. The motor is a B18C5 if that helps any. If any of you can tell me how you hooked up yours, all the hardware needed, it would be greatly appreciated. Thanks.
Old May 30, 2002 | 09:06 PM
Coldsi's Avatar
Default Re: Electrical Oil Pressure Gauge - HELP! (YellowITR01)
I've got a B16A and I ran a steel braided line from the oil sender to the firewall where I hooked up a tee that fed the oil sender and the stock sender. I wouldn't mount the oil sender on the block as it could rattle loose and break off causing MAD damage to your engine.
Old May 31, 2002 | 12:38 AM
b18bvudoo's Avatar
New User
Default Re: Electrical Oil Pressure Gauge - HELP! (Coldsi)
Old May 31, 2002 | 07:44 AM
Crazydave's Avatar
Default Re: Electrical Oil Pressure Gauge - HELP! (vudoo666)
Run a line off the block....
you don't want the big bulky sender hanging off the block that way
you will need a 1/8 BSP to -3 or -4 AN (i forget which) then you will need the SS line for how long you need it to go off the block and mount somewhere...
then a -3 or -4 an to 1/8 npt adaptor don't forget to ground your sender.
Old May 31, 2002 | 08:18 AM
joeygill's Avatar
What do you use to mount the sender on the firewall?
Also, do you keep alot of slack in the braided line from sender to block, to reduce vibes?
Old May 31, 2002 | 08:58 AM
Crazydave's Avatar
Default Re: Electrical Oil Pressure Gauge - HELP! (joeygill)
I used some large brake line holders... look like this _()
and held it on from the tee/adaptor
Old May 31, 2002 | 08:48 PM
Coldsi's Avatar
Default Re: Electrical Oil Pressure Gauge - HELP! (Crazydave)
Put some slack in the line and go to Napa and get some kind of bracket to screw into the firewall.
88crxhfb16
Jul 23, 2005 11:02 AM
2khb
Mar 10, 2005 06:52 PM
W O T
Jan 29, 2005 08:01 PM
Rod.
Jul 29, 2004 11:30 AM
ShortbusEK
Jan 14, 2003 12:29 PM
