Integra Type-R questions
Old May 28, 2002 | 12:42 PM
Dokta's Avatar
Default Integra Type-R questions
Does anyone know how much a stock integra type-R flywheel weighs, or where I can find that info?
What are oil squirters on a B18C5? Where are they located, why are they there, and what do they do?
Are the oil pump and water pump on the B18C5 engines different than those on other B series engines? If so, what is the difference?
Old May 29, 2002 | 01:02 PM
Dokta's Avatar
Default Re: Integra Type-R questions (Dokta)
someone must know the answer to at least one of these.
Old May 29, 2002 | 01:19 PM
hybridreams's Avatar
Dude, why didn't you post this in the Integra Type R forum?
Old May 29, 2002 | 04:39 PM
Katman's Avatar
--it weighs about 17lbs. dunno where you can find one. do a search.
--oil squirters are in every b-series vtec blocks. They're located right below the cylinder sleeves; 1 per cylinder; which aims and squirts right up to the underside of the piston's skirt/cyl. wall area. They're there to aide the engine's lubing system, since all b-series vtec engines are high-reving monsters and need the additional lubing for survival. You won't find these oil spray jets on a non-vtec b-series block.
--the oil pump is the same as a GSR oil pump and possibly a B16A's oil pump too (not too sure on the b16 pump tho). The non-vtec b-series oil pump are not the same internally - b-series vtec oil pumps are basically better, higher flow & pressure rate. The water pumps are the same on all b-series engines.
TurboB16A300Hpteg
Jan 27, 2008 12:16 PM
elcangripapi
Sep 13, 2006 11:26 AM
Sick6
May 4, 2003 03:37 PM
Dokta
May 30, 2002 04:43 PM
