SAFC and VAFC experts. please help!!!
Old May 29, 2002 | 10:35 PM
interlude91's Avatar
Default SAFC and VAFC experts. please help!!!
I have a 3gen lude.. so what i am praying that someone with a 3gen would help.. but all suggestions are needed. I installed my SAFC last weekend. I got all the wire numbers from Tom Coleman. My friend helped me hook it all up. Everything was running fine UNTIL today. I dont know if i'm tripping or not. BUT ever since I changed the pressure settings as per twisted imports on our email conversation for the pressure sensor to 6in and 6out my car didnt run.. it just stalled. So I changed it back to what Tom said in our phone conversation (1in and 1out) ok.. my car is running normal again. I was driving down the road today, and all the sudden I heard this really REALLY REALLY loud POP sound, at first I thought it was this piece of **** truck beside me backfiring , my right ear actually hurt after it happened (i had my sunroof open and my drivers side window open) I looked at my gauges and everything was running normal. Tonite just after I dropped my girlfriend off at home I decided to play around with the monitors on the SAFC. I noticed that my AIR FLAP USAGE % was at 0% all the time.. when I rev nothing happens.. while im driving the monitor doesnt change at all. So I thought to myself WTF is going on... I think it doesnt change unless I change the air/fuel ratios.
KEEP IN MIND I HAVENT CHANGED ANYTHING. meaning the hi, low throttle, and air ratios. I left it stock.. i didnt want to *** with it since I havent dynoed it to tune it with a professional!
I parked in the garage and left the car running. I went throught the setting under the "etc.." menu, and double checked the sensor settings
EVERYTHING IS AT 1in and 1out (as per Tom) when I went under sensor check, my car started to have a rough idle, then it died. I started it, again rough idle, then all of the sudden the check engine light came on. I turned off the car, and turned the ignition key to on, and went through the menus again to double check.. nothing was changed since sunday. So i started the car again, and the car was running fine.
What do you guys think is wrong with my car? Do you guys think the POP sound was my car or the truck? and through this long *** story, did I go wrong with any settings. I read through the manuals and updated pdf's from apexi, they have nothing for a B20A5 engine. It seems like every honda has a "PR-6" as a sensor type.. what does that mean?
If any of you guys have a 3gen lude with a SAFC installed, can you tell me what you guys set everything at (only sensors)
fastacura99
Sep 20, 2006 01:15 PM
tegon-gsr
Aug 5, 2004 07:51 PM
M-EJ1
Apr 4, 2003 12:50 PM
PM-Performance
Sep 3, 2002 09:44 AM
interlude91
Jul 12, 2002 08:07 AM
