CEL light again... code 45
Old May 27, 2002 | 09:27 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default CEL light again... code 45 (rich/lean)
Okay so here's the whole story. abou 2 1/2 months ago I installed a BBK 70MM throttle body into my '99 GSR. i didn't reset the ECU (forgot) but for about a month it ran fine. then the CEL came on and gave me a code 45, running too rich/lean, and i reset the ECU from the advice of someone else. the CEL went off and all was fine, until last night. i was driving to my friend's house at night and it clicked on. it's hard not to notice so i pulled into a parking lot, jumped the service pin and got code 45 again. i didn't know why it showed up so i just reset the ECU to see what would happen. light turned off until i was driving home tonight, and it clicked on again. stopped, checked, code 45 again. so i'm going to take a wild stab and say it's the throttle body.
but why would it be fine until 2,000 miles later? i don't drive my car hard, in fact i hit VTEC a max of like 0-1 times per day. other than the TB the only other engine mod i have is a GReddy SP (spare me the lectures on why i got the TB). yeah, stock airbox, stock ex. manifold. so why now? why is it all of a sudden showing up? could it be gas? i mean something had to be going fine for 2000 miles until now. any help? thanks.
[Modified by dLo GSR, 3:13 PM 5/28/2002]
Old May 28, 2002 | 06:14 AM
Default Re: CEL light again... code 45 (dLo GSR)
Old May 28, 2002 | 09:55 AM
BoM's Avatar
BoM
check your o2 sensor, that might have fallen off and disconnected.
Old May 28, 2002 | 02:18 PM
thanks i'll check it. also, the throttle feels a little sticky sometimes- i press and it doesn't accelerate until a split second later (with a little jolt), but only sometimes. what could be causing this? it's onyl happened since the CEL came on.
Old May 28, 2002 | 04:56 PM
i can't jack my car up right now (garage is full)... could it possibly be anything else or should i just rely on the O2 sensor?
Old May 28, 2002 | 05:33 PM
TypeSDragoon's Avatar
maybe you should WOT your car more often...
Old May 28, 2002 | 06:00 PM
Default Re: CEL light again... code 45 (TypeSDragoon)
i just reset the ECU again, light is off and i idled the car for 15 minutes (last time i had no time to idle it). i'll see what happens. however i did smell fuel- bad sign?
also is it safe for me to drive to and from school (2 miles) like this?
[Modified by dLo GSR, 3:39 AM 5/29/2002]
Old Jun 6, 2002 | 03:26 PM
IVANITR's Avatar
Im getting a CEL 45 also, but why would it relate to the o2 sensor?
leflore
Feb 27, 2015 10:10 AM
dmeconitas
Jul 17, 2009 05:54 PM
snatch
Dec 17, 2004 11:13 AM
aglswapbuffers
Jul 18, 2004 05:32 PM
emanLS
Oct 20, 2003 01:15 PM
