cut springs?
Old May 29, 2002 | 09:54 PM
badnan's Avatar
Default cut springs?
a friend of mine keeps telling me that i should lower my car, but id rather spend the money for lowering springs to save up for a turbo kit.
he says that you dont need to get aftermarket springs and can cut/chop your orignal ones and it works perfectly.
personaly i dont think its a good idea to cut it, but i dont know much. is this method tried n true or is it bad for your car?
Old May 30, 2002 | 03:02 AM
D16Z6racing's Avatar
Default Re: cut springs? (badnan)
your friend is an idiot. never cut or heat shrink your springs. springs aren't expensive.
Suspension Tech. $120
H&R $140
Neuspeed $150+
Eibach $190+
[Modified by buster13, 4:03 AM 5/30/2002]
Old May 30, 2002 | 05:02 AM
Prelude Vtec 23's Avatar
Default Re: cut springs? (buster13)
H&R $140
Neuspeed $150+
Eibach $190+
Agreed, your car will ride like crap. Just spend the little extra money and do your suspension correctly.
Old May 30, 2002 | 05:53 AM
NismoNX's Avatar
Default Re: cut springs? (Prelude Vtec 23)
You can get fairly inexpensive springs anyway.
Old May 30, 2002 | 07:21 AM
SPORT INJECTION's Avatar
eBay!!!!!!! I got my H&R springs used off there cheap
Old May 30, 2002 | 10:10 AM
I Drive A Saturn's Avatar
exactly...if you're going to modify your suspension, do it right or you're just asking for trouble in the future.
-jeremy
Old May 30, 2002 | 10:57 AM
badnan's Avatar
Default Re: cut springs? (I Drive A Saturn)
thats what i thought, thanks fr the help
looks like the suspensions gonna have to wait.
Old May 30, 2002 | 12:16 PM
voltronR34's Avatar
Cut your springs!?!?!
HAHAHAHAHAH
Old Jun 5, 2002 | 08:27 AM
art28's Avatar
Don't cut your springs man, wheels with cut springs tend to slant inward under the car. If take a turn fast enough the force can snap the wheel and your done for. It will cost you more money in the future if you cut your springs. By the way your friend is an idiot!!!
Old Jun 5, 2002 | 09:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: cut springs? (art28)
umm actually any change in ride height that lowers the car will make the wheels have more negative camber (better for handling). However, cut springs increases the rate of the spring (bad for the shocks), and also forces the shock to work outside of its intended range (also bad for the shocks). Power is nothing without control. IMHO you should either upgrade your suspension now, or upgrade it at the same time you get the turbo. A large increase in power on stock suspension could possibly be dangerous.
Old Jun 5, 2002 | 01:14 PM
Rocket's Avatar
Default Re: cut springs? (PatrickGSR94)
You can use cut stock springs if you have some good shocks. I had my 4dr GSR with 4 coils cut off w/ Bilstein shocks and my car handled like a go kart. I could do 90 mph lane changes and the car would just hang - No dip, no biting just horizontal movement. Ride was good too.
But without bilsteins the wheels would load up the springs to much and the car would have major rebound issues along with bottoming out due to less travel space.
Old Jun 5, 2002 | 01:17 PM
Rocket's Avatar
This should be taped on your steering wheel until you upgrade your suspension.
The number one upgrade you can make to your car is handling.
Old Jun 5, 2002 | 01:29 PM
Community Builder
Default Re: cut springs? (Rocket)
I still would not recommend cut stock linear-rate springs, even on aftermarket stiff shocks. While cutting the springs does increase the spring rate somewhat, it's not enough to keep the car from bottoming out, unless the shock has a very stiff compression rate (Konis are only rebound adjustable, also, not compression). One of the reasons why aftermarket lowering springs are a higher spring rate, in addition to improving handling, is to keep the car off the bump stops.
dunkd
Suspension & Brakes
115
May 18, 2016 09:32 AM
treplatano
11
Jul 14, 2005 05:47 PM
xlusiveracer
16
Jun 26, 2005 11:28 PM
91ls-v
Feb 26, 2004 07:56 PM
Tofurky
Oct 7, 2002 04:42 PM
