CRX - Rev problems
Old May 31, 2002 | 07:37 AM
CRX-stevie's Avatar
Default CRX - Rev problems
I've got a CRX Si 1988 standard. A few times a day(while i'm driving or Parked with the engine on) it will rev on its own sometime up to 6000rpm and then it will drop to 750rpm. It will just rev in between that backet. And then it will stop on 750rpm for a bit and then go back to 1000rpm. The engine warning light will come one while this is happening. But if you turn the engine off and back on the warning light will go off.The engine warning light will comwe on if you start racing?
Any help will appreciated.
Old May 31, 2002 | 07:42 AM
six_speed's Avatar
Default Re: CRX - Rev problems (CRX-stevie)
there might be a leak w/ ur throtle body's gasket....check that and the idle screw.
Old Jun 1, 2002 | 10:01 PM
jrcrx's Avatar
Default Re: CRX - Rev problems (Lilmumbler)
It could be numerous of things, TPSensor, throtlle cable getting stuck, etc....
shadowhunter55
Feb 21, 2016 05:37 AM
delboydavies
Honda CR-V & Element
Sep 9, 2014 08:55 AM
blink_977
May 21, 2009 12:45 AM
Phrost
Aug 1, 2007 06:31 AM
cliffjumpercrx
Jan 14, 2003 09:01 PM
