Check engine light > Primary o2 Sensor??
Old May 30, 2002 | 07:44 AM
eTec's Avatar
Default Check engine light > Primary o2 Sensor??
Got a cel yesterday out of nowhere. Took it to the dealer and they plugged in the machine and it read faulty primary o2 sensor. Can't really figure out why it would go out on me. The dealer is charging $187 for that thing!
What are my alternatives? I've called local auto parts stores to see if they have replacements but they don't. Is it ok to buy a used one? Will it harm anything if I keep the bad sensor in for too long?
Old May 30, 2002 | 08:33 AM
oldbeefcake's Avatar
Default Re: Check engine light > Primary o2 Sensor?? (eTec)
Buy an universal one, but you need to figure out the wires, because they have different colors than the OEM. It will be cheaper. ask someone here for the wire diagram when you get one.
Old May 30, 2002 | 09:45 AM
gsrvx's Avatar
New User
I just recently got the same code. Lemme know where you find a replacement. I know sohfast.com has em for like $70...but they are used. I'd rather get a new one.
-rod
Old May 30, 2002 | 12:41 PM
Perfectionist's Avatar
You could buy a used one, but how good is it? Running a bad sensor may cause a slight performance decrease, fuel efficiency decrease, and possibly cat converter damage but not too likely.
FWIW, I tried two generic Bosch sensors and they didn't perform well for me. I had to use OEM honda. Try places like hparts.com or hondaautomotiveparts.com for discount prices on OEM parts.
Old May 30, 2002 | 03:42 PM
eTec's Avatar
Default Re: Check engine light > Primary o2 Sensor?? (Jun)
Is this the universal one your talking about?
http://www.jcwhitney.com/product.jht...equestid=59677
Old May 30, 2002 | 09:09 PM
Coldsi's Avatar
Be careful with non-Honda O2 sensors. My experience is that the ECU only likes to read a Honda sensor. I had a problem with my sensor and tried to install an MSD O2 sensor and couldn't get it to work. I broke down and ordered the stock sensor with the plug in.
Old May 31, 2002 | 02:24 AM
eTec's Avatar
Default Re: Check engine light > Primary o2 Sensor?? (Coldsi)
Did you buy it from the dealer? Even hondaautomotiveparts.com sells them for $175 which is still high.
Old May 31, 2002 | 08:50 PM
Coldsi's Avatar
That's about the cheapest I've seen them for.
Nando613
Honda Civic (2001 - 2005)
Mar 29, 2015 05:38 PM
vtec2nv
Apr 12, 2013 04:52 AM
mr devious illusions
Jan 26, 2006 11:47 PM
turrismaldon
Jun 19, 2002 05:55 AM
