VAFC Throttle Output issue
Old May 30, 2002 | 02:44 PM
Asahi's Avatar
Default VAFC Throttle Output issue
Here is the original question with all the updates. ANY input is much appreciated.
https://honda-tech.com/zerothread?id=195357
Old May 30, 2002 | 03:25 PM
superR303's Avatar
New User
Default Re: VAFC Throttle Output issue (Asahi)
I a similar problem with the Vafc on my R, but it just read differently with engine running vs. not running. it didnt jump around. I now have the unit installed in my HB civic, with the same engine and ecu, different wiring harness(civic ex) and no problems. the only difference then was the factory wiring harness. the vafc should get ground from the ecu harness and not chassis metal, but I'm sure apex'i would have asked you to check that already. good luck!!
Nagata-San74
Honda S2000
Dec 8, 2007 07:03 PM
CHRIS 1.8
Oct 1, 2003 12:43 AM
Greg456
Aug 12, 2003 09:06 AM
IgniteTeg
May 1, 2002 03:13 AM
George H
Feb 15, 2002 01:33 PM
