Urgent help with clutch differences!!!!!!!!!!
Old May 31, 2002 | 05:52 PM
sirminder's Avatar
Default Urgent help with clutch differences!!!!!!!!!!
can some one please tell my why the new exedy clucth disc is diff than the oem that came off the engine. i first thought i bought the wrong one. but according to clutchcityonline, i do infact have the correct one HCD015U for a 95 b16. i went to the dealer and compared the one that came off the engine with the correct replacement. and both new and old are identical. so what do i do? here is a pic. the top two are the stock disc both sides and the bottom is the exedy both sides. notice the spline height on the top (stock) is higher than the bottom (exedy). my mechanic says that it fits on the crank but the diff with the new one is gonna make it harder to put it in gear. please help
Old May 31, 2002 | 06:47 PM
non-VTEC's Avatar
Default Re: Urgent help with clutch differences!!!!!!!!!! (sirminder)
no two clutch disc's of diffrent manufactures will look alike. i have the same exedy clutch and it works fine
install it and enjoy..................also read the special attatched peice of paper included with the exedy clutch kit. it specifically addresses the fact that some of the honda/acura clutches may not let you shift into gear properly........and it explains how to fix that as well.
good luck......
Old May 31, 2002 | 08:21 PM
sirminder's Avatar
Default Re: Urgent help with clutch differences!!!!!!!!!! (non-VTEC)
can u or someone else help me out with this documentation that is included in the box like mentioned above. i did not find anything in the box. non-vtec, so do u think i should go ahead and install it. its been nearly 3 months since i bought my engine. and i really wanna finish with my swap. but i dont want to pay twice cuz the clutch is wron. please help me
Old May 31, 2002 | 10:34 PM
TypeSH's Avatar
good luck......
do you still have that paper? What exactly does it say about hte problem and the fix? Any mention on h-series or f-series clutches? I was sold on getting an exedy when I get a chance until I saw your post...
Old Jun 1, 2002 | 04:40 AM
non-VTEC's Avatar
i dont have that peice of paper anymore.
if you e-mail clutchcity online they should be able to scan you a copy or send you one.
it bassically said that there have been some cases of after installing the exedy clutch that it might be difficult to put the car into gear or difficult to shift gears. they offer a simple procedure to adjusting the clutch pedal to fix the problem.
on my car there was no adjustment needed it shifts fine.....
Old Jun 1, 2002 | 02:27 PM
sirminder's Avatar
well unfortunatly with today being a sat, everyone is closed and i wont be able to figure it out til monday . i was just able to get a hold of two people. but those guys are salesmen and know nothing technical about my situation. im just very confused cuz i do have the correct parts for the clutch. and i just wanna get a confirmation that it will still work without any problems. anyone else?
Old Jun 1, 2002 | 03:15 PM
keebler65's Avatar
ok, first of all, you dont want to touch the disc surface like you are in the picture. the oils will mess it up and cause it to fail alot quicker. its not too late, just clean it with brake cleaner or somethin.
secondly, i found my papers for my exedy clutch. here's what it said:
"we have had some of out installers that encountered a problem when installing some of our clutches in honda/acura applications where it feels like the clutch is not releasing properly.
if the clutch release bearing is traveling too far, it can be pushed onto the hub of the clutch disc and push the disc onto the flywheel. the tranny cannot be shifted and the will feel like the clutch is not releasing.
the normal tendancy in this case is to adjust the linkage to get more release bearing travel, but this only makes the above situation worse.
if you feel that this may be happening, try VERY GRADUALLY letting up on the clutch pedal by about a couple inches while LIGHTLY trying to shift the tranny. if as you let up on the clutch pedal, you can easily shift, the the problem is not that you do not have enough release bearing travel, but that you have too much travel.
if your car is a late model that has a hydro tranny, then you will need to adjust the push rod on the clutch pedal. you will need to loosen the lock nut and turn the threaded section so as to shorten the push rod.the actual pedal travel will not change as there is a slot in the push rod and there is a spring holding the clutch pedal up against its stop. this will make for more free play at the top of the clutch pedal travel and a shorter release bearing travel. this should cure your problem.
if your car is the earlier model with a cable clutch system, you will need to adjust more free play into the system."
hope this helps, my typing isnt the best.
Old Jun 1, 2002 | 04:24 PM
sirminder's Avatar
Default Re: Urgent help with clutch differences!!!!!!!!!! (keebler65)
Keebler65, u are my hero!!!!!!!!!!!!
crewdawg88crx
Dec 3, 2008 02:26 PM
Redwidow
Nov 2, 2006 08:23 PM
dazuk
Mar 2, 2006 11:52 AM
EF8 JUNKIE9
Mar 19, 2004 11:47 AM
miketegra
Jul 4, 2001 08:02 AM
