Airbag question
Old May 29, 2002 | 07:40 AM
jhortillano's Avatar
Default Airbag question
Hi Guys,
I own a 99Civic Si and I just recently removed my airbag to remove the steering wheel and once I put everything back, the airbag light doesn't turn off. I rechecked all my connectors and made sure I didn't leave anything disconnected. Still the Airbag light doens't turn off. What could cause this? I've also reset the ECU by removing the 7.5 fuses and letting it sit of like 10minutes while I ate dinner. Is there something else I'm forgetting to do? Any help would be appreciated..
Old May 29, 2002 | 08:01 AM
unltdacc12's Avatar
Default Re: Airbag question (jhortillano)
did you disconnect the battery when you removed the airbag??
Old May 29, 2002 | 08:03 AM
dmotoguy's Avatar
Default Re: Airbag question (unltdacc12)
hopefully you did!!! that is very dangerous not to
Old May 29, 2002 | 10:11 AM
Default Re: Airbag question (dmotoguy)
Yes I did. I didn't want to spark anything and that damn thing blow up on me.... I think I may have found a solution... hmmm...
Thanks,
-Jason
Old May 29, 2002 | 12:06 PM
t's Avatar
t
Reseting the motor ecu will do nothing for your SRS light. You need to reset the SRS ecu.
pmptwst17
Mar 22, 2007 08:55 AM
EK45VTi
Jan 11, 2005 01:11 PM
R-Lug
Nov 16, 2004 06:37 AM
SleeperRSX
May 12, 2003 06:45 AM
jhortillano
May 29, 2002 10:12 AM
