coil over Vs. progressive rate springs
Old Jul 8, 2002 | 10:48 AM
DUFFY's Avatar
Default coil over Vs. progressive rate springs
what are the advantages and disadvantages to adjustable coilovers Vs progressive rate springs. can anyone help make this decision easier. it is a daily driver and there is winter where I live
Old Jul 8, 2002 | 10:58 AM
builthatch's Avatar
MiG-21 superfan
Default Re: coil over Vs. progressive rate springs (DUFFY)
coilover offers height adjustability, but alot of the time the sleeves are paired with junk springs or mismatched to the strut application...progressive rate springs are those that the rate increases exponentially according to how severly its compressed, they offer reasonablysmooth ride that soaks up bumps and undulating surfaces nicely but when loads are applied, they become more of a performer, stiff, etc. your best bet is to get progressive springs on a threaded body strut with dampening adjstment capabilities...progress group makes nice setup, i run it...
ps...is that motor in your avatar a 3.6 ferrari motor?
Old Jul 8, 2002 | 11:25 AM
DUFFY's Avatar
Default Re: coil over Vs. progressive rate springs (builthatch)
yup, keen eye
thanks for the info how do progressive rate springs perform in the snow?
Old Jul 8, 2002 | 11:32 AM
builthatch's Avatar
MiG-21 superfan
negligible difference, good or bad, if any at all...tires is the key in the snow IMO
btw, ive a 91 348ts
[Modified by builthatch, 3:34 PM 7/8/2002]
Old Jul 8, 2002 | 12:08 PM
ILUVTEC's Avatar
I dont think that this question is worded quite right, I think he means either 'linear' rate or 'progressive' rate, or he just wants to know if he should put adjustable coilovers(most likely using linear rate springs) or just performance springs(linear or progressive) on his car. Just my thoughts....
Old Jul 8, 2002 | 12:45 PM
DUFFY's Avatar
Default Re: coil over Vs. progressive rate springs (ILUVTEC)
I understand progressive rate springs and that is what i meant. whats a linear rate spring? is it a normal OEM spring. Can you use progressive rate springs with adjustable coilovers
[Modified by DUFFY, 5:48 PM 7/8/2002]
hugebob
May 21, 2012 09:10 PM
ej8ray
Suspension & Brakes
May 28, 2011 09:09 AM
JPerkMr954
Suspension & Brakes
Jan 18, 2011 01:10 PM
92CivicLSI
17
Nov 11, 2004 02:04 PM
Flux
May 2, 2002 08:18 AM
