URGENT: VAFC install help... ASAP!!!
Old Jul 6, 2002 | 08:35 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default URGENT: VAFC install help... ASAP!!!
i'm installing my VAFC right now and i need this done by tonight, and i've run into a little problem before i've even opened the wires.
my car is a 1999 acura integra GSR 4 dr. now, according to apexi's *updated* instructions, all 99+ models should use this wiring diagram:
notice that the area 2 has wires located in it.
however when i pulled out my ecu and took a look, it looked exactly like this:
notice that area 2 has no wires in it. however, this is the diagram for 96-98 models. i am somewhat confused because mine is a '99...
now logic would tell me to go with the one that looks like mine. but i just want to make sure that i should be using diagram #2 (H-6) rather than diagram #3 (W-3) on my '99. can't be too careful
Old Jul 6, 2002 | 08:50 PM
Default Re: URGENT: VAFC install help... ASAP!!! (dLo GSR)
urgent!
Old Jul 6, 2002 | 09:04 PM
yellowbuffalo's Avatar
bseries.net
Old Jul 6, 2002 | 09:12 PM
Default Re: URGENT: VAFC install help... ASAP!!! (slipknot23)
bseries.net
hi. i've been there. i'm using it. it doesn't give ECU-specifics.
Old Jul 6, 2002 | 09:52 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Use diagram H6-a. It's the only one that matches up with the wiring harness. That should work fine.
However, on my '99 GSR I had to connect the VTM Signal wire on the 31P connector which is the blue/black wire. On the 31P section (your section #3) with the ECU pinouts facing you, it is the #15 pin counting from the top row, left to right and continuing on the second row.
Good luck!
[Modified by Gee3, 12:56 AM 7/7/2002]
[Modified by Gee3, 12:57 AM 7/7/2002]
Old Jul 6, 2002 | 11:06 PM
Default Re: URGENT: VAFC install help... ASAP!!! (Gee3)
Good luck!
thanks a bunch man! it's in and works like a charm
Supa_Slow_Civic
Dec 24, 2004 09:38 AM
typesguy
Dec 23, 2004 04:59 AM
wutangben
Aug 12, 2002 11:15 PM
jteasy
Sep 17, 2001 07:42 PM
