Hondata stage 4 (no boost)
Old Jul 8, 2002 | 08:38 AM
titebast's Avatar
Default Hondata stage 4 (no boost)
I guys... this my firts post but i'm reading a lot on the forum....I think my english is not to bad but i'm a french person .......
I wont a buy a hondata ecu but i'm not sure what stage.. 3 or 4.. I wont read some feed back about hondata and all stage you try....
Here is my setup....in a civic 90
Ecu: p72 (gsr94-95 ob1)
motor: B16A2 97
full rebuilt.....
piston oversize
three angle valve
blue print....
boost the oil pomp (85psi)
balanced 9500rpm...
port and polish stage 1 advanced...
flywheel 11lbs
race clutch
custom cam
cai
itr headers
2.5 exhaust all the way...
I was thinking to buy a v-afc and chip my ecu ..... but i hear about good thing on hondata and i think it will better to buy one thing that will do all that **** and more .... i don't wont have dash like F&F in my car... i don't wont a flash with my little computer on seat but i like to play with my setup and upgrade it with my tech friend...
P.S. i'm not a show guy... i'm all go no show....
[Modified by Bast_b16, 5:40 PM 7/8/2002]
Old Jul 8, 2002 | 09:00 AM
Spade's Avatar
Default Re: Hondata stage 4 (Bast_b16)
The difference between Stage 3 and 4 is insane....however, if you get Stage 4 you can burn others ECU's with the software that is included.
Might be a big advantage in France....
Old Jul 8, 2002 | 10:41 AM
titebast's Avatar
Default Re: Hondata stage 4 (Spade)
I will be able to burn oem ecu or only hondata ecu... I now there is a big difference... I just won a now if the sofware is nice... i don't wont to setup my car one time and because it's so hard and difficult to setup that i will now longer use de computer.....is it a flexible program....
how much whp i will be able to have on b16...
Old Jul 8, 2002 | 01:50 PM
doc's Avatar
doc
With Hondata Stage 3 you'll get a chip for your ECU, Hondata-Box, wires, clutch switch, Led. Just put it in your ECU, connect the hondata box and you can play around with rev-limiter, vtec-point, ...
With the stage 4 you'll get also the hondalogger (to connect your laptop and see a lot of your engines parameters) and the romeditor (to reprogram your and maybe others hondata chip)
With the Hondata Romeditor you can just program Hondata-ECU-Chips. A Hondata ECU need the Hondata-Box all the time. It dosn't work without!
You need the laptop only when tuning or datalogging - during normal operation there is no laptop needed - so no f&f style.
To tune you need also a WB O2 Meter. This will cost also some bucks. (some $100 up to some $1000) You need also some time and a dyno(time). (= $$$)
BUT, you can purchase stage 3 and find a Hondata-Tuner next to you who will tune your car with his/her Hondata Stage 4.
Old Jul 8, 2002 | 05:04 PM
titebast's Avatar
Default Re: Hondata stage 4 (doc)
tanks a lot...
hYpE-R-29
Apr 6, 2003 11:33 PM
SilverS
Feb 6, 2002 07:26 AM
Pro-Lude
Oct 4, 2001 02:55 AM
sgT
Aug 16, 2001 09:46 PM
