Problems with my Clutch
Old Jul 10, 2002 | 06:40 PM
KooK's Avatar
Mustang Sally
Default Problems with my Clutch
My pedal goes down 2/3rds of the way and then starts to catch... When I replaced the clutch I didn't take apart the Hydo. Line. Heres the Kicker, I dont know if it was like this before I bought it. Could I have installed the clutch incorrectly? I know the Throw Out bearing is in place and I'm pretty sure I lined everything up correctly.
Do you guys think I just need to bleed or could it be something else?? Thanks!!
By the way, its a 91 Eclipse GS
Old Jul 11, 2002 | 03:28 AM
John's Avatar
New User
Default Re: Problems with my Clutch (KooK)
It could be one of two things:
1) Adjust your clutch pedal height.
2) You may have blown your clutch master cylinder. If your new clutch has a stiffer pressure plate, a lot of times it'll result in the death of your clutch master cylinder.
While you're at it, I'd recommend bleeding your clutch hydraulic system and replacing it with fresh DOT 3 fluid. Unfortunately, this type of maintenance usually goes unchecked.
xxgriffonxx2
Transmission & Drivetrain
Apr 28, 2010 10:18 AM
veilsides2000
Honda S2000
Jan 30, 2009 02:20 PM
LOC714
Sep 23, 2004 12:34 PM
geminis2k
Nov 20, 2003 11:33 AM
SikofFalln
Apr 25, 2003 02:49 PM
