Gsr Skunk2 Intake Manifold installation problem!!! help plz.
Old Jul 5, 2002 | 10:58 PM
Spyder500's Avatar
Default Gsr Skunk2 Intake Manifold installation problem!!! help plz.
just installed a GSR skunk2 Intake Manfoild on my gsr.
bolted everything back on and the tubes.
used a brand new GSR intake manifold gasket.
Its leaking coolant!!!
not from the tubes... where the Fat coolent tube on the intake manifold. but between the Intake Manifold and the Head (where the gasket is).
i tighten the bolts hella tight again but still has a leak.
any suggestions on fixing it guys????
need info ASAP.
car cant run with out coolent.
I was thinking of taking it off again and using some liquid gasket along with the my new gasket thats already on it but making it leak!
plus any good tips on removing the old gasket from the head? tried Carb Cleaner still a little left on it!
[Modified by Spyder500, 8:00 AM 7/6/2002]
Old Jul 5, 2002 | 11:14 PM
GreenD's Avatar
Default Re: Gsr Skunk2 Intake Manifold installation problem!!! help plz. (Spyder500)
sounds like that could b the problem. that ***** a PITA to get off. ive heard of a couple people getting air leaks from not scraping it off good enough.
i used a gasket scraper and some penetrating lubricant, letting it soak for a few minutes. torque sequence is also important. hth
Old Jul 5, 2002 | 11:19 PM
Spyder500's Avatar
Default Re: Gsr Skunk2 Intake Manifold installation problem!!! help plz. (GreenDestiny)
really torque sequence is important also huh
whats the pattern to bolt it back on?
i just bolted it in and just slaped it on. cause u kno those bottom 4 nuts are a pain to put on cause its so hard to get too!!!!
u think its the bits of the old gasket thats creating a gap and causing the leak?
will Carb Cleaner get that old gasket off and scrape it with a knife or something?
Old Jul 5, 2002 | 11:50 PM
GreenD's Avatar
your supposed to start from the inside out in a crisscross pattern. i cheated put it on while the head was off the car.
it could be, somethings not making it seal right. i dunno if carb cleaner would work or not, try wd-40 and dont cut yourself.
casper_hb
Oct 5, 2009 09:47 AM
Shizznaz
Sep 2, 2005 08:07 AM
speedymon
Aug 9, 2004 11:16 PM
BoostedGSRBubble
13
Jun 7, 2002 12:31 PM
