Type R throttle body on B16 in CRX
Old Jul 7, 2002 | 05:19 AM
spettinger's Avatar
Default Type R throttle body on B16 in CRX
hey--need help with wiring a type r throttle body with the electric map sensor into a 91 CRX SI. thanks
Old Jul 7, 2002 | 03:30 PM
ULTRA911's Avatar
Default Re: Type R throttle body on B16 in CRX (wreckedhatch)
just find some wires to extend the plug to run to the itr map sensor that is on the TB. that's all.
Old Jul 7, 2002 | 08:54 PM
spettinger's Avatar
Default Re: Type R throttle body on B16 in CRX (ULTRA911)
what about the solenoid on the map sensor? do i connect them to anything? thanks.
Old Jul 8, 2002 | 12:28 AM
frogsr's Avatar
could you possibly post a pic of the "solenoid" on the map sensor you're referring to? i'm not familiar with the crx map sensor, and its location, but hopefully some more info from you could help us help you.
if the plugs on the two map sensors (crx vs. itr) are the same, you could just extend the wiring and plug and play. this would mean you'd have to have the actual map sensor that sits on top of the itr throttle body.
Old Jul 8, 2002 | 05:02 PM
spettinger's Avatar
Default Re: Type R throttle body on B16 in CRX (frogsr)
i will try to get some pics. thanks.
Old Jul 8, 2002 | 05:21 PM
Katman's Avatar
that solenoid is a seperate part from the MAP sensor.....ignore it and just extend the MAP wire senor's plug to the MAP sensor on top of the ITR tb.
Old Jul 9, 2002 | 11:27 AM
GM2000ITR's Avatar
New User
ITR throttle body is pointless on B16 intake manifold. You will not flow any more air into the IM than what it's capacity is regardless of the TB bore.
Old Jul 9, 2002 | 02:14 PM
Katman's Avatar
Default Re: Type R throttle body on B16 in CRX (GM2000ITR)
well he might gain some velocity since the ITR TB is tapered out bigger in comparison to a stock B16 TB....but you're right about the volume of air the TB and manifold will let in.
jphil101
Apr 2, 2010 11:36 AM
killacam661
11
Dec 2, 2007 04:41 PM
EgSalad
Jun 6, 2007 12:12 PM
Pooper
Oct 16, 2006 09:19 PM
SVOboy
Mar 26, 2006 11:48 AM
