B16a into 3g Integra can someone help??!!!...
Old Jul 7, 2002 | 01:19 PM
nosmas's Avatar
Default B16a into 3g Integra can someone help??!!!...
need some help , what mounts need to be changed or is it all right to use the b16 stock mounts. i know i have to change the side mount on the timing belt side can ne one help or give me a resource page for b16 into 3g integras
Old Jul 7, 2002 | 06:11 PM
lazy bum shaughn's Avatar
Default Re: B16a into 3g Integra can someone help??!!!... (nosmas)
Sorry this doesn't you, but why are you putting a B16A motor in a 94-up Integra?
Old Jul 7, 2002 | 11:36 PM
salbaje's Avatar
yeah why?? anyways what year b16 is it?? if its 2000 si b16 then you need to get the 2 top mounts and rear bracket. also gsr driver side motor bracket
Old Jul 8, 2002 | 01:05 AM
nosmas's Avatar
Default Re: B16a into 3g Integra can someone help??!!!... (salbaje)
just so i can sell the car its a b16 95 jdm motor in a 3g integ and the motor was a deal
what mounts are needed or need to be changed ?
besides the side bracket
[Modified by nosmas, 10:13 AM 7/8/2002]
[Modified by nosmas, 5:53 PM 7/8/2002]
Old Jul 8, 2002 | 09:02 AM
nosmas's Avatar
help please
Old Jul 8, 2002 | 09:43 AM
eg6ajk's Avatar
if you are using second gen B16A, then reuse the stock mounts....all should bolt up... (2nd gen b16a came with two types of mounts on the driver side - 92-3 d-series offset and 94-5 d-series parrallel)
otherwise just bolt on your b18b mount to the block and be done...
for 1st gen b16a, electronics, mount, 02 sensor, thermostat housing with sensor, bottom mount added
egb16pg
Feb 2, 2007 04:47 PM
Revolemilbus
Jul 2, 2005 02:27 PM
LD_EGSICK
May 10, 2004 05:35 AM
hyper em1
Apr 21, 2004 06:34 PM
90CIVICSI
Jan 15, 2002 08:17 PM
