Z10 Block Girdle?
Old Aug 28, 2002 | 06:55 PM
Alpha_GSR's Avatar
Default Z10 Block Girdle?
Yes I've already done a search, and I might add I learned quite a bit.
However, it didn't answer all my questions:
Can I have the girdle machine and doweled for my block without removing my motor from my car? Also, if someone can post pictures of what all exactly needs to be done, thanks.
Kong
Old Aug 28, 2002 | 07:21 PM
boomslang's Avatar
Default Re: Z10 Block Girdle? (Alpha_GSR)
https://honda-tech.com/zerothread?id=263598
Old Sep 1, 2002 | 01:20 PM
555R's Avatar
i doubt it can be done in the car...I know of portable boring machines but never heard of that setup for a milling machine
remove the block
there are enough of you guys that it can be done in 30 minutes
Old Sep 1, 2002 | 01:22 PM
sgT's Avatar
sgT
You need to remove the block.
The main caps will have to be doweled with the girdle and then the main
journals will have to be align honed.
DA9tothewheel
Engine Machining & Assembly
Aug 21, 2016 02:48 AM
HyperFlow
Aug 5, 2010 11:11 AM
JDM00SI
Nov 1, 2005 10:53 AM
