Any diff between obd1 del sol vtec head b16 and 99 b16 head
Old Aug 26, 2002 | 11:01 AM
GeorgeJetson's Avatar
Default Any diff between obd1 del sol vtec head b16 and 99 b16 head
as far as obd go??? Is it just the distributor, or is it some sensors also?
Old Aug 26, 2002 | 11:12 AM
Spade's Avatar
Default Re: Any diff between obd1 del sol vtec head b16 and 99 b16 head (georgejetson)
Cams
Old Aug 26, 2002 | 11:29 AM
Default Re: Any diff between obd1 del sol vtec head b16 and 99 b16 head (Spade)
really whys that, i just need to know, doing a b20 vtec with a b16 head, camn i dont care about just the obd part
Old Aug 26, 2002 | 11:41 AM
Spade's Avatar
Oh.....injectors and distributor.
Old Aug 26, 2002 | 12:54 PM
X2BOARD's Avatar
I think the older B16 has single valve springs on both intake and exhaust. But the newer model have doubles on the intake cam... but I could be wrong.
X2
Old Aug 26, 2002 | 12:59 PM
sgT's Avatar
sgT
Default Re: Any diff between obd1 del sol vtec head b16 and 99 b16 head (X2BOARD)
X2
Yep. you are wrong.
Past 1992 all the heads are the same. only differences are external parts
like injectors and distributor.
Old Aug 27, 2002 | 05:46 AM
X2BOARD's Avatar
Default Re: Any diff between obd1 del sol vtec head b16 and 99 b16 head (sgT)
X2
Yep. you are wrong.
So is the double spring at least true on the b18c heads ?
Old Aug 27, 2002 | 10:55 AM
Katman's Avatar
yes...
The same rules for 92+ B16A heads apply to 94+ GSR heads as well, as far as valvetrain, ignition, fuel injectors, and sensors go...
serr38
Oct 12, 2007 04:52 AM
jdmkid8383
Jun 24, 2007 06:03 PM
Rightside
Jul 12, 2004 10:12 PM
Dragger817
Oct 14, 2002 05:37 PM
