H23A VTEC- Is there such a motor?!
Old Aug 25, 2002 | 05:31 AM
Arch-Angel's Avatar
Default H23A VTEC- Is there such a motor?!
I've got a 92 Si Prelude with a H23. Is there a VTEC version of my engine?! (not the H22a)
Old Aug 25, 2002 | 08:25 AM
VTECorona's Avatar
Default Re: H23A VTEC- Is there such a motor?! (Arch-Angel)
No, but you can put a H22 head on it and it'll be a VTEC monster.
Old Aug 25, 2002 | 08:43 AM
boomslang's Avatar
Yes it exists. It was only available in certain Accords overseas. Very rare.
Old Aug 25, 2002 | 08:48 AM
VTECorona's Avatar
Default Re: H23A VTEC- Is there such a motor?! (Inlinefour)
I think thats the F20B accord SiR-T motor with the blue valve cover. It looks like the H22. Its on http://www.jdmhondaparts.com I think.
[Modified by 97RedTegGSR, 6:34 PM 8/25/2002]
Old Aug 25, 2002 | 03:50 PM
Arch-Angel's Avatar
Default Re: H23A VTEC- Is there such a motor?! (97RedTegGSR)
REALLY?!?! What do I need!??!?!? Would I use the parts off a H22? PLEASE TELL ME WHAT I NEED TO MAKE MY H23 VTEC!!!!
Old Aug 25, 2002 | 03:53 PM
phase's Avatar
From: HELP i am under your moms bed,, and you dad just got home
the f-means sohc the 20-means the displacement 2.0 so i doubt it would be that one. i know that a h22 head can marry a h23 bottom. ask doctor wong he knows much on this subject
Old Aug 25, 2002 | 03:59 PM
BoredNStroked's Avatar
Default Re: H23A VTEC- Is there such a motor?! (phase)
My friends shop has an F20 DOHC motor out of a japanese accord......It looks just like a H22 but with a blue valve cover and sportshift auto tranny......Its for sale.....
Old Aug 25, 2002 | 04:01 PM
Arch-Angel's Avatar
What is doctor wong's username? I searched, but didn't find anyone by that name...
So, sorry to sound naive, but what is the 'head' that I need? Would I just need the cams off a H22? What about the ecu?
This would be so much better than just dumping a H22 in my engine bay
PLEASE tell me more!!!!
Old Aug 25, 2002 | 04:04 PM
Arch-Angel's Avatar
Default Re: H23A VTEC- Is there such a motor?! (BoredNStroked)
If I was going to buy the whole engine, i would probably just go for the H22. But thanks anyway.
What I am really looking for is converting the engine I have to VTEC. (That would still work out cheaper right?)
Old Aug 25, 2002 | 04:43 PM
Hondaaccordvtec's Avatar
Ok, the H23 Vtec motor is found in 97' and up accord wagons in Japan. It does come w/ a blue valve cover. And yes, they are very rare. Expect to pay a premium for it.
Old Aug 25, 2002 | 06:08 PM
VTECorona's Avatar
You're pretty knowledgeable phase (sarcasm)
Old Aug 25, 2002 | 06:47 PM
93PGTZE's Avatar
OKAY LOOK!!
Just go and buy the top end off a h22a motor... The motor is a H22A , and thats the motor you ask for , when wanting to buy the top HALF of the motor( all of it not just the cams but everything but the bolck which is the bottom half)
YOU THEN JUST BOLT THE BITCH ON , thats it.... You have vtec....
Old Aug 25, 2002 | 08:05 PM
Arch-Angel's Avatar
Default Re: H23A VTEC- Is there such a motor?! (93PGTZE)
So there is no need to go and get a new ecu?
And will it remain the same displacement as what I have now (close to 2.3L)?
mmm, 2.3 VTEC... this is gonna be sweet!
Thanks to everyone who has helped me out with this question, all the info is truely appreciated! I promise to let you all know how the bitch turns out in the end!
If anyone has any more opinions/advice for me, PLEASE don't hesitate to post or email me at Arch-Angel@optushome.com.au
Cheers all!
Old Aug 25, 2002 | 08:44 PM
VTECorona's Avatar
You will need the H22 ECU to run the H22 head. Your transmission and axles from your H23 should be compatible. If you don't want to go through the headache and don't mind losing the .1 liter of displacement (2.3 liter to 2.2 liter) then just buy the complete H22 swap. It goes for about $2300-$2400 and it comes complete with complete motor, transmission (LSD for additional $400 I think), axles, ECU, and sometimes the gauge cluter I think. Check http://www.jdmhondaparts.com and http://www.ardperformance.com
Old Aug 25, 2002 | 08:58 PM
Arch-Angel's Avatar
Man Jap engines are expensive in the US!
I was quoted $2200 AUD for a H22 half cut that had done 90,000 klms here by a few different places.
That works out at about $1200 USD!
Those links you listed have H22 half cuts for $3800 USD! there is no way I am paying $7500 AUD for a H22!
I might look at keeping the h23 and changing the head over to a h22 like you said. now all i gotta do is find a good mechanic to do the work! (no one down here knows about these engines!!!)
Cheers.
Old Aug 25, 2002 | 09:53 PM
VTECorona's Avatar
Just must have went to the wrong link or something. Go to jdmhondaparts.com, click the intro image, wait for the menu to appear, click Engine -> Engines we carry. You will see H22A for 2500 complete swap or 1200 for longblock only.
Old Aug 25, 2002 | 10:39 PM
raene's Avatar
I might be wrong but isn't a halfcut the front half of a car?!? So for USD$1200 you get the entire front half of a 'Lude... that's my impression anyway...
Old Aug 25, 2002 | 11:40 PM
Arch-Angel's Avatar
Default Re: H23A VTEC- Is there such a motor?! (raene)
Yes, thats right. can get the whole front end of a gen 4 lude for around $2200 AUD. Think that includes cluster as well i think.
Whats a 'long block'? is that the motor only? If so, that wouldn't really suit me, since I would need the ecu and wiring as well...
It seems a lot of things are different over here!
Old Aug 26, 2002 | 07:56 AM
VTECorona's Avatar
Plain and simple if you want a JDM H22 motor spend $2500 for the complete swap. If you really want to dig around and find just the head and ECU seperatly then be my guest, be prepared for a headache.
Old Aug 26, 2002 | 02:11 PM
Arch-Angel's Avatar
OK, OK, I see your point. The only reason that I ask is because I talked to my mechanic the other day and he advised against doing the complete engine swwap with a H22. he said that he had done a couple before (when he used to work for Honda Australia) and that it was a pain in the butt. He reckons its easy enough to just dump the engine in, but to get it running correctly takes time, and at $60 an hour that is going to cost the earth.
I am interested in finding out more about he head simply because it sounds easier to do. I am not going to be bothered looking for 'half an engine', I will probably just buy a half-cut but look at only fitting on the H22 head to my h23 block. I can just send the rest of the H22 block to the scrap yard for all i care, or even use it for parts...
So I guess, what I am trying to find out is which swap is easier to do... Just assume that I have a H23 in my car and a H22 half cut sitting next to it. Would it be easier to implant the entire H22 or just marry the h22 head to my H23 block?
94b18hatch
Oct 3, 2007 02:11 AM
snowblind7x
Jan 29, 2005 05:01 PM
92-LS-Civic
Jun 11, 2004 11:57 PM
two fast 4 you
Dec 28, 2003 08:23 PM
4thgenturboSi
Apr 24, 2002 08:28 PM
