SRS light!!
Old Aug 25, 2002 | 09:57 PM
** OF HAZARD's Avatar
Default SRS light!!
I just rebuilt my motor on my 7thgen civic! Everything is great but the SRS light is on!! The bags never went off so what could it be? Any ideas? THanks in advance!!
Old Aug 25, 2002 | 10:00 PM
Stryker908's Avatar
Default Re: SRS light!! (7thgencivic)
Clock spring ? fuse ? didnt reconnect the airbag to the airbag controle unit ... still pluged in to the airbag service port ..... could be lots of things
Old Aug 25, 2002 | 10:07 PM
Default Re: SRS light!! (JDM_SIR_II)
i did have the right seat out!! Everything is plugged in!! If i reset my ECU do you think it may turn off?
Old Aug 25, 2002 | 10:50 PM
Stryker908's Avatar
You can try I have heard something about taking both battery cables off and touching them together ..... I wouldent do it though untill you can conferm this is correct with somebody else ...
Old Aug 26, 2002 | 07:00 AM
rbf351's Avatar
use the service connector and see what code u are getting
Old Aug 26, 2002 | 07:42 AM
yaya's Avatar
my srs light is on in my 5th gen,,,, its a blown fuse, but the fuses for the SRS are kinda not accessable....i think cuz honda doesnt want you tryin g to fix your airbags....you are SUPPOSED to take it to an airbag certified mechanic
i mean i could tear into the fuse section and rip out the fuses, but maybe there's a certain way to go about it, i dont want my airbag knocking me out cold, so ill leave it alone for now
Old Aug 26, 2002 | 11:23 PM
iam7head's Avatar
Default Re: SRS light!! (BrianP)
If you sure about the you didnt mess up the air bag part just take it to the dealer(70bucks for reset) or just take off the blub from the guage. The air bags will still work. I tried the jump wire trick(something to do with the yellow plugs) and the +/- connector trick, they didnt work for my 6g accord nor my 1g legend.
I got the SRS light came on after i removed my front seats so i'm pretty sure my air bags will work. i posted a similar topic but none of the tricks works.
hope this help
pumafeet10
Oct 23, 2005 09:29 PM
transitions
Sep 19, 2005 10:44 PM
intevic_dx
18
Sep 16, 2004 08:41 AM
Speed Racer GSR
Nov 17, 2002 05:19 PM
EGkTiOn_CiViC
Aug 30, 2002 06:03 PM
