anyone done this with a B18c1 swap???
Old Aug 1, 2003 | 06:34 PM
fu*kfaceC1EH2's Avatar
Default anyone done this with a B18c1 swap???
I have a 95 EH2 and B18c1 motor, and have been without an o2 sensor for a few days. Instead of getting a GSR cat where it will plug into, anyone add wire and make the civic o2 sensor longer...and plug it into the header?? my rs*r header has the flex pipe in, and i don't want to mess with exhaust right now, so i'm wondering if anyone's done this with their swap..and if it was throwing code for it??? thanks.
-danny
Old Aug 1, 2003 | 06:55 PM
Mohudsolo's Avatar
Default Re: anyone done this with a B18c1 swap??? (fu*kface95hatch)
If you have an OBD1 motor, I don't think it will be a problem. All it will do is move the sensor a few inches upstream of the GSR placement. It's mostly the OBDII that gets pissy about sensors and locations. An OBD1 does not even care if there is a cat. The main thing is if you are in a state that cares much about swaps, in which case you will have to make it like the GSR to be perfectly legal. As far as running properly, I doubt you will see any problems. You may not make full power with the header and cat from the different motor though.
Old Aug 1, 2003 | 06:57 PM
Default Re: anyone done this with a B18c1 swap??? (Mohudsolo)
yeah it's an OBD1 motor, and it's going upstream about 3 feet.. well i'll give it a shot, thanks bro
RidingMark
Mar 3, 2007 08:14 AM
DC2_Integra
Mar 19, 2003 04:39 PM
SjCiViCHB
Feb 25, 2003 12:44 PM
Rob Dizzle
Dec 1, 2001 06:15 PM
Rob Dizzle
Nov 30, 2001 10:46 PM
