LS/VTEC ppl, maybe you can help.
Thought I would get more help here https://honda-tech.com/zerothread?id=578327
no the ls manifold wont bolt on
you should upgrade to a gsr oil pump and vtec waterpump and yes use vtec timming belt.
if you use ls water pump then use ls timming belt
i would recommend getting either a type r or skunk 2 intake manifold, which ever one is less expensive. also you'll a vtec water pump and vtec timing belt.
LSVTECJW
Oct 23, 2007 03:22 PM
99EletronblueSI
Oct 19, 2004 11:13 PM
